Retrofit Electrical Rear Sun Blind
Alex5522
Need helps:As title mention i bought the Ori used rear sun blind online with the the ori used ASC and Sun Blind Switch Module last week. And now was at Top Cushion to re-wrap the fabric to matching back my existing colour.Used Electrical Sun Blind Looks
Used ASC & Sun Blind Switch Module Looks
The problem was after i receive the stuff and try to plug in the switch module to my car it was not working. Since my car came without the rear sun blind so i notice the Switch Module was difference then my existing one. Can some one tell the above switch module are for E46 model or others model?My original Switch Module looks
When i plug in the ASC connector to the used switch module and press the button my cluster traction control indicator didn't lights up, so i guess it must be the switch module not fit to my model or it was spoil one which the seller sold to me. Hope some one help and guide me how to test the switch module are in good condition or not. Thanks
When i plug in back my existing switch module and press the ASC button my cluster traction control indicator lights up
I notice too if i need to use the switch module which i bought my existing Air Cond Compartment Bezel need to be replace also
Hopes all the sifu can help and guide me to complete this Electric Rear Sun Blind to my car.Appreciate and thank you very much in advance from me.
Last time JKP also selling the same thing for e39. He did mention that the wiring is different from certain year to year. I try to get the thread but seems the thread is already deleted by moderator.
Alex,
I have the instructions for the e46 retrofit. PM me your email address.
IanDaddy;663862 said:
Alex,
Bro IanDaddy
Thanks a lot and very appreciate it, already PM you.
Update some close view of the ASC+SUN BLIND SWITCH MODULE
There was two connector slot on this module
Closes looks Top Small Slot & Bottom Big Slot
Can see the IC Board inside the module and the ventilation hole
My Original ASC Module Which Was Conceal Together With The Bezel
Back View Of My ori ASC Switch Which I can't See any IC Board On It
Can all sifus and otai otai tell will this ASC+SUN BLIND MODULE can use on my car
Since there was two connector slot at the ASC+SUN BLIND Module so what sort of connector that i was short out from my existing wiring and where can i get it ?
FYI my Ori ASC connector cable are just fit nicely to plug in to the Top connector slot of the ASC+SUN BLIND Module. But then how about the Bottom Big Slot ??
Couldnt you swap the single button panel to the new one. You mention that the existing ASC connector slots in fine into the sunblind button panel, then the other connector should come with the sunblind to wire to rear of car. Show us the wiring harness that comes with the sunblind.
Bro very sorry at the moment the sun blind still in Ah Kit Top Cushion Shop for re-wrapping and as what i remember there was a electric motor attached on with a pair of wire which got a male connector only. No wiring harness provided, i guess i need to send to the wiring shop to do the wiring since my car origin are without this thingy. The others was the ASC+SUN BLIND Switch Module which i bought from the seller as the photo i posted that's only i have from the seller. By 2molo i will go to ah kit shop and pick up the sun blind then will show you the photo.
Anyway thanks a lot for the info provided to me bro.
Bro no point for me to swap with this ASC+SUN BLIND Module Switch cause as i said i did test plug in the connector to this switch module and press the ASC button my cluster traction control indicator didn't lights up (Refer photo 4&5). So it means it was not function on this module either this module was not fit to my car or it was not in good condition.
There is a possibility that the switch module is broken, but most probably it is not compatible with your car. As I understand there are only two wires going to the sunblind motor, so the wiring is relatively simple. Maybe what you could do is modify the button panel that you bought to accomodate your car.
Hmmm sounds like the switch is broken or not coded in your car :(
Bring the switch to a reputable electronic shop to test out the functions. I guess when you complete the wiring it should work (with 12v supply)
Cheers to another gred mod to the car... me? i settle with #1 (darkest) Tint... :p
Update some photo of the retrofit !
Only two wire attached from the electric motor of the sun blind
The female connector looks
The "C Pillar" need to dismantle when the installation carry
The rear view of the sun blind looks
The completion fixed looks but the wiring still pending
Use back my existing rear speaker cover
My existing rear speaker without sun blind become rojak alrdy he..he..
The speaker panel parts no
The speaker parts no
The last part haven't complete are the switch control wiring. And it is quite difficult to
find the ori sun blind switch to install on the existing ASC Button Bezel to make it looks OEM.
Thanks for viewing and sorry for the poor image from my Nokia phone
Yup sifu i know but it was quite late liow after fixing it from ah kit cushion shop some more i still can't find the switch lar..
Could use a simple up/down switch while searching for the proper switch
jarance;664690 said:
Alex, nice mod!! but you should have got it working before installing it.
Do you know where to find this Sun Blind Switch which can fit next to my ASC Button Switch ?
This one too big lar bro..tarak cantik sama kemas wor...
I am trying to find the one have the sun blind icon on the button OEM looks one..mana mau cari ya !
