WTCooperman
- May 7, 2012
- 14
macgy;747395 said:I assume u hv replaced d fuel filter located underneath d car, there is also a fuel regulator attached to it, that is similar to d one on d engine, in fact u may be able to reuse it if u still keep d part, pls chk w ur mech.
In ur case when this happen, try to re start d car, it has to start at 1st crank & immediately....does d car back to normal?, from my experience the failing throttle body replicate same symptom but CEL light will came out but urs don't.
I am a noob and didn't know about the fuel regulator.
Yes the fuel filter is located underneath the car somewhere near the front passenger side if I am not mistaken.
When the problem happened, my car will start at first crank almost immediately, but it will not come back to normal i.e. there is no power like I what described (the engine sounded normal, no violent vibrations etc., just that there was temporary power loss). I had to turn off and restart to get the car moving. Once the car moves I am OK and from the last occurrence (some +3 weeks back) till now, the car is behaving well despite the fact that I do get stuck in similar bad start/stop traffice crawl in KL. Fyi there is no CEL light.
Thanks again and much appreciated.
