Rear humming noise
mielo86
Sifus and bros,As per the tittle mention above, i've been having this issues since 2011 and it still bugging me until now. so far i've changed the rear tyre bearing and axle oil..i've also try to swap my axle with halfcut but still to no avail..it seem that this noise is stuck and wont go away..it's a real headache to try to solve this issues.Realy need your help sifus..this problem make me feel shy to join the club TT=p:106:
We can cross bearing and axle oil off the list then. Does the humming happen only when you are moving? try checking your long shaft, rear shaft, tires.
The noise come when you drive over 80km/h..forgot to mention that i've also change the center bearing for the longshaft..the tyre also new michelit ps3...and also change axle mounting...
could be the tires...try swapping them with the front ones. Eliminate the most easier and FOC part first... :)
my rear tyre is new, just 1 month old::burnout:
mielo86;773771 said:
As per mentioned before, that also have been change..
u used ori or taiwan? my friend here used a taiwan bearing and it was no good..changed to original bmw unit and humming noise gone..
hahah...hear i go again...isit a whining before the humming??
[video=youtube;tYo4VUojFds]http://www.youtube.com/watch?v=tYo4VUojFds[/video]
this is my car last time...change alot things...rear diff, tyres, bearing...end up with long shaft...some member here change U joint, some rebalance long shaft....for me...chop shop long shaft save the headache...
I think it's the same noise...if not mistaken, the center bearing for my longshaft and guibo/rubber thinggy have been replaced..i think i've covererd almost 80% of posibilities except for drive shaft and longshaft...senang cerita saya dah hantar mekanik dan kebetulan dia ada simpan satu axle dengan longshaft so boleh try and error..sempat try axle saja sbb longshaft tak sama jenis...dah tukar axle masih tak hilang bunyi so dia ganti axle lama balik..tinggal longshaft saja saya tak try lagi..ada sapa-sapa sini yang tau kedai boleh testing dulu tanpa perlu terus kena beli longshaft?
mielo86;790667 said:
im looking for e46 318i auto long shaft..anyone has spare in possession?
Bro aidilj may still have his after his conversion to manual.
Bro if im not mistaken, bro aidilj long shaft is steptronic(correct me if im wrong) which is abit shorter from mine fully auto..
Thanks bro..by the way which link refer to mine?thinking of sourcing from chop shop...what price am i looking at for the long shaft?which chop shop you guys prefer to go?
thanks eujinee..will do some surveying tomorrow around segambut and jalan ipoh. hopefully can get a cheap and reliable long shaft..whish me luck..keke:eek:
my friend here just re-furbished his e34 longshaft, done by a new engineering shop in BP...rm650 solved his issue...
