Real Quad Exhaust System
M.Street
I am not so happy with my current quad setup, I am using one side s flow and the other one straight thru, pick up is fine but lost the low end torgue during slow drive, so I am looking to these set up, just want some comment and will these set up solve my problem? Thanks.They are using Magnaflow tru X for center box and run each side with resonator,as what they dyno and the result gain power, but I am not sure about the low end torque, what you guys think?
google other owner lo end toq results from this set up.on another note,plse be mindful of the exhaust pipe heat issues that may arise long term if it is allowed to run under the cv joint rubber boot and the differential as this diff(in the pic) has an oil cooler fitted for a reason. :cool: heat shielding will do good
Noted. Thanks. Moots, I can not find the link, please help for the link.
