Radiator Heat -Any Advise
KelvinTeoh
Banned
Any idea my E46 heat!i try pour coolant and remove the themostat,still same after i travel 30 minits,up and down the water temp!Forman advise me to remove the Tangki let professinal to wash,have u try before,is it works?
huh?
what is your problem
Try all water first until you solve your heat problem.
why u remove the thermostat? if your temp goes up n down, u better check the whole system. is your fan ok? water pump? dun play2 with bmw cooling, its a very costly affair.
I had changed my termostat and radiator before. Most probably your radiator got problem. go and check...
is it works?
How is the temperature gauge moving:-
1. between quarter to middle or
2. between middle to 3 quarter or
3. 3 quarter to redline.
Coolant only help to reduce by a few degrees and in addition protect the radiator from rust and scaling.
To do radiator flush do not required that the radiator to be removed.
Pls have it check out carefully and immediately to avoid overheating to your engine.
