question;redline
iCe
i'm driving E30 325 with auto transmissionis it normal when the rpm meter go over the red line (8 X 1000) when u accelerate ?just curious because most of auto transmission car i ride before,never reach redline,it change gear before reach redline.
Originally posted by bmwky@Jul 15 2005, 09:57 AM
are you running m20b25 engine with a 4.10 diff?
i dunno.,how to check.
sorry,newbie here.
:D hey Ice..nice car u have there.use to have one myself but mine was manual.
auto trannies are programmed not to exceed the engine's redline to avoid engine damage.if u floor it to the max,the box will shift just as it hits the redline..
Redlining your car is NOT in the best interest for your engine's health.....auto & manual. For Auto, if it is a standard set-up ( gearbox, rear diff ratio, rim/tyre size ), red lining should NOT happen.
Btw, check your Tacho & it's sensor at the end if you have verified all mechanical parts are okay....and it still redlines!
Find the reason and fix it......
aik...M20 can revs up to 8000rpm meh..???? :eek:
ask axle to explain this he knows it well. he is having this problem hehehehehe
It will also redline if you are using the a 4-pot meter on a 6-potter. I have experienced this before... my rpm goes all the way to the other side :p I mean all the way to the consumption gauge.
how to know its 4 potter or 6 potter?what is potter anyway?
my ride is a conversion from 318 to 325.i dunno if my dad still using the 318 meter after the conversion.is this the matter?
I was under the impression driving the car to the redline occsionally removes any excess carbon buildup in the engine?
I drive a E46 318i with the 2.0 N42 and i rev 500rpm past the redline on a daily basis.
Even my gf's E46 320i with the 2.2l revs 500rpm past the redline.
I think maybe the first 1000 - 1500rpms of the redline is more of a security to prolong engine life and not so much the fact that there will be any adverse effects on operability and long term life of the engine... I THINK. :D
Dont call me if your engine kaboom when u rev to redline. Heheh
I do it anyways..
The redline begins at 6000rpm (or whatever). The fuel cut off is 500 rpm after that. Hope that explains.
