chaiks
- Dec 13, 2004
- 357
- 18
Sad day it was in parting with my e34. I'm getting an e39, so that itself is good but started spending on e39 already, but that's another thread. Not sure I listed my parts expenses before, but just for the last time. Things that I did in there that I can list from a booklet I kept, all manuals & service history is with the car handed to the dealer. 2003/01 Brightness cheras 1. Fan guard 2. Power steering box 3. Intake manifold hose 4. O-ring kit seal 5. Power steering rack kit 6. Bonnet absorbers 7. Termostat housing c/w O-ring 8. ATF oil 9. Power steering high pressure hose 10. Power steering oil Total 2,650 2003/01 Brightness cheras 1. Fan motor assy(original) - 1230 2003/03 Naidu 1. Idle Bearing 2. Compressor Pulley bearing 3. A/C Belt Total 400 2003/2 M-Speed USJ1. Micro filter 2. Radiator level switch total 400 2003/03 M-Speed USJ1. Fan belt 2. Fan belt tensioner 3. Fan belt bearing 4. Water pump 5. Knock sensor 6. Manifold gasket 7. Exhaust sensor 8. Fuel filter total 2300 2003/3 M-Speed USJ1. Fuel pump 2. Fuel hose 3. Gearbox mounting 4. R/Pitman arm total 1300 2003/4 Bavarian Auto Part SS21. Engine Mountings 2. Tie rods side 3. Centre tie rod 4. Anti Roll bar 5. Swing support 6. Rear A/R bar bushes total 700 I realize that the above is only 4 mths into the ownership, and did a gearbox overhaul by M-speed USJ, and countless other wear and tear stuff ever since. If anyone looking for a good condition, standard e34 1994 Automatic in metallic blue, can call the dealer Darren 012-2338827. Just let him know its recommended by Chai of BMWClubMsia forum, should surely cut some good discount. I'm a fussy owner, surely its good for the car and the next owner. Bye.
