oil leaking problem
aangavatar
My E39 525i, m54 is losing oil, 1.5 lit every 1000km, it is getting unbearable. Sent to the mechanic and was told of a long list of possibility that need replacement...crap.I decided to DIY, suspect oil filter housing is leaking at the block & probably the dipstick o ring need replacement too.I will try to take some photos to share later , this is the first time i am going to do this, wish me luck.
managed to removed the air filter box, the belt and next removed the alternator, can see more clearly now, leak is bad
got it, thanks, here r the pictures
air filter box, alternator removed-
oil filter housing removed, bad leak:eek:
oil filter housing:
oil filter housing-after cleaning, note: i seal the hole with tape while cleaning with brake cleaner
cause of leak, hard and brittle seal, i broke it while removing the seal
Bro, did u post the wrong link, i didn't see any post abt your car's oil leak problem
