newbie: e90 2006 mkn minyak + whiteeee smoke...
Firdaus712
i juz bought my 2nd hand e90... i need to topup 1 lt engine oil every 3000km and my car produce white smokeee...aduhhhhh plisss plisss help meee~
i think its quite common to any cars this problem. Guessing its the gasket issue. Have you encountered any overheating ?
White smoke is a bad bad thing my friend. Usually white smoke produced due to pistons eating up your blocks.
Usual solution will be overhauling. (Other sifus, Please correct me if i'm wrong)
It's a valve seal. Do check on other discussion threads. The engine oil is burn in the combustion, thus producing a white smoke. You can check your exhaust tip is still dry. The remedies will be top overhaul. Valve seal can be repair by some workshop but they will need a special tool to remove the valves. It will cost between 3k to 5k inclusive of oil separator change.
Waaaaa...top overhaul~!!.... i will construct with pomen..hopefully only valve seal problem...ok thanks guy
E90/325 n52b25
How's mileage km ?
maybe due to leakage valves sealed .
alamak same problem with me....minyak hitam kena makan....aiyoo 3-5k repair ayoo yooooo huhuhuhu jahanam laie duit den.... Banyak Makan Wang oooo...
hari tu masa gi JB from kl...speeding around 140kmh - 170kmh...esoknya parking kereta enjin masih hidup dalam 30 minit tgk ada kuar asap putih....then cek tgk indicator minyak hitam sudah kurang....huhuhu... my car 2007 model 320i
Whats a car mileage ?
have check engine any oil leakage ?
Maybe due to valves sealed faulty .
Tq
Firdaus712;827172 said:
my problem done..only need to change valve seal cost about 500myr jerk.. :)
Where is this workshop, I want to check it out. Please give the address. Tq
Bro Firdaus
Sorry I cant reply your PM as your inbox is full, however you can contact Ah Tee at Hoo Huat @Segambut next to Goodyear for the topoverhaul bro.
sorry bro...i havent open this forum for along time...my millage is about 120km, the workshop is somewhere in penang near mecalister road opposite AmanahRaya building..Hyper-Genic Sdn Bhd..i will give the address later..
