New Key
Thanks, your link is much better and basically suit much more to your requirement and problem.
Jarance.
Well, I guest will try to open my key and have a look when I back to Sarawak.... Thank you very much... I have learn alot of new things from you....
azeL_Inc;395171 said:
yup...same goes to me..it doesnt sound when i press lock..it sounds when i try to manually open the door lock by using the key. so does it means our car have alarm? i think we do..haha
I think the answer to your question is rather obvious.. LOL
Ah Yew;395176 said:
Jarance.
No problemo.. you are welcome. :wink:
Hi all broos, wana ask regarding our keys..
the key come in 4 unit per set rite? 2 main unit, 1 service key and 1 wallet key.
just to clarify...
Hai kby*88*.....I think that is if you buy new car...If you buy recond car, than is much depending on your luck... My friend buy recond E46 320i, he got complete set. Me and 1 of my friend also bought E46 320i, but we're not that lucky, we only get 1 remote key and 1 wallet key....
Hope this answer your question....
I m one of the lucky guY! hehe :top:
to add, can the wallet key be used to start the engine?? (i don t read the manual ok! LOL)
looks like i'm not so lucky.
i only get 2 remote key.
as far as i know, the wallet key also con be use to start the engine. am i correct?
correct me if i'm wrong..
yup....you can use any key to start the engine....
Last time I try to lock the car by using the remote key, and I open the door manually and start the car by using the wallet key....
doesnt the alarm activated when u manually open using the key?
Not if you use the key on the door handle and turn it extra (45 deg). :listen:
just to clarify...
This depend on what year is your model.
From year 2001 till 2002 - 4 keys
From year 2003 till 2004 - 3 keys.
erm..i dont really get u..what do u mean by extra 45? normally we turn 90 degrees only rite? so do u mean if we turn 135 degrees, the alarm won't sound?
Sorry, I was confuse with my E36..:eek:
The correct procedure for E46.:wink: Please refer to below:-
i think i did that, but the alarm was activated..n since i was just testing for the alarm, i can easily press the unlock button on the remote and the alarm went off...
if in the real remote malfunction case, i wouldnt know how to turn off the alarm...yet...
:p
anyone knows?
:p
anyone knows?
Bro, when press "Unlock" button on remote, it should deactivate the alarm.. How come your one triggered the alarm.. :eek:
erkk...thats mean people that have our wallet key can start and drive away the car easily...
huh,worried d...
huh,worried d...
Bro, it depends on what spec is your car.
What spec is your E46 model and year?
Anyway, will verify the above. i.e. whether Valet key can de-activate the alarm if the master remote have set the alarm..
Normally, I would think the alarm would go off.
The valet key is meant to be use to start the car and lock the door manually. I would it is sensible that you pass the valet key to the car jockey to park your car. Normally, you would stop the engine, remove your master key and hand over the valet key to the car jockey. You do not activate the alarm.
Quite an interesting question..
