bro, not sure abt the particular model, but based from bro V-man recommendation
http://www.bmwclubmalaysia.com/foru...e-purchase-Checklist-Workshop-recommendations :
The Standard Checklist:
Car Info
• Build date
• Make
• Model
• Miles
• Exterior color
• Interior color
• Modifications
Test drive
• Strange noises/rattles?
• Feel solid?
• No excess vibration
• Car tracks straight
• Idle is constant and smooth
• Clutch test: On a slight incline at ~30 mph, put the car into fifth gear and floor it. Does the clutch slip?
• Any CELs or SRS or any other lights on in the dash?
Cooling System
• Hoses (cracks, fitments, etc)
• Where does needle sit on the water temp gauge?
• No dry coolant visible in engine bay
• Is the engine driven fan still present?
Engine
• Belts (cracks)
• Pulleys (any excess noise/play)
• No excess A/C compressor noise
• Any suspicious oil residue under car?
• Condition of gaskets: Oil pan/timing cover/valve cover/head
• Air filter is in decent shape?
• Intake boot is not cracked
• Oil level is in range of ‘half full’ to ‘one half quart over max’.
Exhaust
• Muffler mounted securely
• Heat shields are secure and don’t rattle
• No deteriorated/rusted areas
Transmission/Differential
• All gears engage/disengage smoothly.
• Clutch pedal feels solid.
• Clutch line isn’t leaking
• Is the clutch delay valve still present?
• No transmission seals are leaking
• Transmission mounts are securely installed and not worn
• Guibo/Flex Disc is not cracked or worn
• CV boots are in good shape
• No excessive play in joints
• No differential seals are leaking
Power Steering
• Reservoir is full
• No PS fluid leaks from the hoses/rack/reservoir
• The wheel turns without making excess noise at parked idle
Suspension
• All bushings are solid and not cracked or worn
• Front control arm (2)
• Front sway bar (2)
• Rear shock mounts (2)
• Rear trailing arm (2)
• Upper and lower (wishbone) outer rear ball joints (4)
• Upper and lower (wishbone) inner rubber fittings (4)
• Rear sway bar (2)
• Rear sway bar endlink (2)
• Differential carrier
• Rear Subframe (4)
• Area where rear subframe is connected to body is solid and not cracking
• Shocks/dampeners are solid and not leaking fluid
• Tie rods are in good condition
Brakes
• % pad left:
• % rotor life left:
• Brake lines don’t leak
• Caliper doesn’t leak
• Caliper boot is intact
• Reservoir doesn’t leak
Tires/Wheels
• Do all tires match?
• Tire size(s):
• Tire brand(s):
• % tire life left
• Tires are worn evenly
• Wheel finish isn’t chipped or cracked
• No excess caked-on brake dust on face of wheels
Exterior
• All body panels match exactly
• Have any body panels been repainted or worked on?
• Any significant dents/scratches/rock chips
• Headlights are not pitted or cracked
• No rust or clear-coat peeling
• No lights out
• No windows are cracked
Interior
• Dashboard is in good shape and not cracked
• Glovebox does not sag
• Owners manual is in glove box
• Windows auto-up function works and doesn’t stop halfway up
• There are not significant tears/rips in interior
• No strange smells
• Has the car been noticeably smoked in?
• No lights out
• Stereo/speakers work
• No speakers are blown
• Climate control works
• A/C blows cold
• OBC screen is intact
• Are windows tinted? If so, approximately what %?
• Tint is not peeling or fading
• All interior panels are in good shape and not ripped or faded
