Change BMW E90 VO vehicle order with ICOM NCS-expert
jankenda
New Member
[SIZE=10.5pt][FONT='宋体']BMW owners are able to enable or disable car retrofits or features by changing [/FONT][/SIZE][SIZE=10.5pt]the[/SIZE][SIZE=10.5pt][FONT='宋体'] VO (vehicle number) or FA string. The coding option can be done with [/FONT][/SIZE][SIZE=10.5pt]BMW coding tools [/SIZE][SIZE=10.5pt][FONT='宋体']BMW ICOM [/FONT][/SIZE][SIZE=10.5pt]ISTA/P engineering [/SIZE][SIZE=10.5pt][FONT='宋体']and programming [/FONT][/SIZE][SIZE=10.5pt]software[/SIZE] [SIZE=10.5pt]NCSExpert[/SIZE][SIZE=10.5pt][FONT='宋体'].[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Tool needed:[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']BMW ICOM a2+b+c [/FONT][/SIZE][SIZE=10.5pt]diagnostic[/SIZE][SIZE=10.5pt][FONT='宋体'] system [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']BMW ICOM ISTA/P ISTA/D [/FONT][/SIZE][SIZE=10.5pt]software[/SIZE][SIZE=10.5pt][FONT='宋体'] HDD[/FONT][/SIZE][SIZE=10.5pt][FONT='宋体'] with engeering [/FONT][/SIZE][SIZE=10.5pt]software[/SIZE][SIZE=10.5pt][FONT='宋体'] NCS-expert [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Instruction:[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Code CAS:[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Well install BMW ICOM [/FONT][/SIZE][SIZE=10.5pt]software[/SIZE][SIZE=10.5pt][FONT='宋体'] HDD and NCS Expert [/FONT][/SIZE][SIZE=10.5pt]software[/SIZE]
[SIZE=10.5pt][FONT='宋体']Connect [/FONT][/SIZE][SIZE=10.5pt][FONT='宋体']BMW ICOM A2+B+C OBD2 diagnostic tool [/FONT][/SIZE][SIZE=10.5pt][FONT='宋体']with vehicle via USB or wifi wireless connection [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Open NCS-expert file [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Select File>>Load File>>Expert Mode, press OK[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Press F1: VIN/ZCS/FA button [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Press F3:[/FONT][/SIZE] [SIZE=10.5pt]ZCS/FA f. ECU [/SIZE][SIZE=10.5pt][FONT='宋体']button [/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Select BMW CHASSIS type:E89 in [/FONT][/SIZE][SIZE=10.5pt]the[/SIZE][SIZE=10.5pt][FONT='宋体'] list, press OK[/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Select ECU type: CAS, press OK[/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Then the NCS Expert [/FONT][/SIZE][SIZE=10.5pt]software[/SIZE][SIZE=10.5pt][FONT='宋体'] screen will display Chassis module, VIN number and VO/FA information [/FONT][/SIZE]
[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Press F2: Enter FA to [/FONT][/SIZE][SIZE=10.5pt]change[/SIZE] [SIZE=10.5pt]the[/SIZE][SIZE=10.5pt][FONT='宋体'] vehicle order [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Again select chassis type: E89 [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Confirm [/FONT][/SIZE][SIZE=10.5pt]the[/SIZE][SIZE=10.5pt][FONT='宋体'] VIN number list is correct [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Enter [/FONT][/SIZE][SIZE=10.5pt]the[/SIZE] [SIZE=10.5pt]Service Code[/SIZE][SIZE=10.5pt][FONT='宋体'] or SA in [/FONT][/SIZE][SIZE=10.5pt]Attribute text field[/SIZE][SIZE=10.5pt][FONT='宋体'] on Enter VIN [/FONT][/SIZE][SIZE=10.5pt]program[/SIZE]
[SIZE=10.5pt][FONT='宋体']---Service Codes begins with a [/FONT][/SIZE][SIZE=10.5pt][/SIZE][SIZE=10.5pt][FONT='宋体']+[/FONT][/SIZE][SIZE=10.5pt][/SIZE]
[SIZE=10.5pt][FONT='宋体']---SA codes begins with a [/FONT][/SIZE][SIZE=10.5pt][/SIZE][SIZE=10.5pt][FONT='宋体']$[/FONT][/SIZE][SIZE=10.5pt][/SIZE]
[SIZE=10.5pt][FONT='宋体']Press F6:Back button [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Pres F4: Process ECU button [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Choose ECU type: CAS, press OK[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Press F2:Change Job button [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Select [/FONT][/SIZE][SIZE=10.5pt]FA_WRITE[/SIZE][SIZE=10.5pt][FONT='宋体'] from Choose Job [/FONT][/SIZE][SIZE=10.5pt]program[/SIZE]
[SIZE=10.5pt][FONT='宋体']Confirm [/FONT][/SIZE][SIZE=10.5pt]the[/SIZE][SIZE=10.5pt][FONT='宋体'] CAS module is [/FONT][/SIZE][SIZE=10.5pt]selected[/SIZE][SIZE=10.5pt][FONT='宋体'] and [/FONT][/SIZE][SIZE=10.5pt]the[/SIZE][SIZE=10.5pt][FONT='宋体'] job name is equal to [/FONT][/SIZE][SIZE=10.5pt]FA_WRITE[/SIZE]
[SIZE=10.5pt][FONT='宋体']Press F3: [/FONT][/SIZE][SIZE=10.5pt]Execute[/SIZE][SIZE=10.5pt][FONT='宋体'] Job button [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Code LMA[/FONT][/SIZE][SIZE=10.5pt]:[/SIZE]
[SIZE=10.5pt]Write[/SIZE][SIZE=10.5pt][FONT='宋体'] the new VO to LMA ECU module [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Press F1: Change ECU button [/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Select LMA ECU type in C[/FONT][/SIZE][SIZE=10.5pt]h[/SIZE][SIZE=10.5pt][FONT='宋体']oose ECU program, press OK[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Confirm LMA ECU module is selected and [/FONT][/SIZE][SIZE=10.5pt]the[/SIZE][SIZE=10.5pt][FONT='宋体'] job name is equal to [/FONT][/SIZE][SIZE=10.5pt]FA_WRITE[/SIZE]
[SIZE=10.5pt][FONT='宋体']Press F3: [/FONT][/SIZE][SIZE=10.5pt]Execute[/SIZE][SIZE=10.5pt][FONT='宋体'] Job button[/FONT][/SIZE]
[SIZE=10.5pt]The coding[/SIZE][SIZE=10.5pt][FONT='宋体'] has ended.[/FONT][/SIZE]
[SIZE=10.5pt][FONT='宋体']Exit BMW ICOM [/FONT][/SIZE][SIZE=10.5pt]NCS Expert[/SIZE] [SIZE=10.5pt]software. [/SIZE]
[SIZE=10.5pt][FONT='宋体']Disconnect [/FONT][/SIZE][SIZE=10.5pt][FONT='宋体']BMW ICOM diagnostic system.[/FONT][/SIZE]
http://bmwicomseries.webs.com/
