bmw7833
- Oct 14, 2006
- 9,160
- 48
haywire;622618 said:Hmmm...wonder whats this PM business....:listen:
Nothing secret talk la..Just pass him a short msg.
bimmerholic;623061 said:Bro, noticed your car on hoist in Jason's w/shop on Wednesday. Wanted Jason to check something on my car. Also noticed a red E39 with V8 under the hood. Looks like it just recently got transplanted! Swweeeet!
Iylia H;624762 said:Brooo no updatesss ahhhhhhhhh?
ICEMAN 13;624797 said:i saw a e34 moster bearing some johor plate thats got an alpina emblem at rear and was seen taking the small road exit right infront of herritage workshop ... freaking awsome with huge fat wheels ...
YaZmEeN;625386 said:eggie's car will be like that in a month time...
redlotus;625599 said:Eggie bro, there was a set of Alpina rims for e32 for sale on mudah, just saw it today during lunchbreak, check it out bro. Caps were missing and not sure if they were ori though...
bmw7833;625611 said:How about the other one? 17" in e36, can use spacer in your car.
U can see the spacer (purple color alu) attach to the wheel hub in the picture.Wheel spacers create clearance/space between the wheel and the hub (mounting spot) which increases clearance from the inner wheel well.
bmw7833;625621 said:Spacer will make the rim looks outer if you mount the higher offset rims on your e32. I think e36 sharing the same hub size with e32, so what u need to do is make the wheel outer. Not every one like to use wheel spacer anyway.
U can see the spacer (purple color alu) attach to the wheel hub from the picture.
Eggie86;625624 said:Thanks for the clarification bro. Now I know what spacers do! So, meaning that the rims will be pushed even outer, to get a wider stance?
Iylia H;625636 said:exactly... but in the case of using 3 series wheels on ur e32, then it'll be as if the rims were meant for your car (as long as you use the correct size spacers to create the effect)
