Jarance,jarance said:Yes, go for angel eye.make sure it is SMD LED type and not the CCFL.
If you are leaking coolant, check that first.
rsdn26 said:For starters,
1) engine oil change with shell helix ultra 5W-40 4 liters
2) LH absorber link changed
3) Front disc skimmed. Now feels way better while braking. No sterring judders -> Why skim it? Changing a new disc only cost you merely 100+/pcs (OEM brand Brembo)
4) New 4 tyres. S/stone atlantis v7 215/45/17. No more pulling left and more silent.-> Thought our default tyre size for 17" should be 225/45, but undeniable 215/45 is more commonly available and price also can be up to 30% with the same tyre size.
Next task in pipeline
5) Gear oil change (GM gearbox)
6) spark plug change
7) t/shoot steering freeplay while at high speed -> Try look into the short & long coupling, which is a common wear & tear part. However, mine still have the problem eventhough after changing them, so I guess mine could be the sterring column or the whole power sterring rack having problem.
8) t/shoot intermittent power loss while driving between 2k to 3k rpm-> Not sure how your power loss feel, but after I changed my cooling fan clutch, it feel much better. This is quite a common problem for our car since we are using mechanical fan clutch. The clutch should cost <RM300.
9) radiator expansion tank, thermostat and radiator check for leak. Topping up water 300ml bi-weekly.-> Suggest you do a compression test first. to see where the leakage. Normally the spare tank and the radiator cap are the easiest replacement. Worst case is the radiator leak and have to change a new unit.
Sent from my ASUS_Z010D using Tapatalk
I've gone through the similar path few years back when I bought my 320i.rsdn26 said:10) replace all 4 absorbers. Not sure go for boge auto, or used gab adjustable.-> Personally I've use new abs than used unit, it's wear & tear parts, not worth choosing used part. Normal OEM brand is BOGE or SACH, both about the same, but for mine I replaced BOGE at the front & SACH at rear (both replace at different timing). My suggestion is if replace both & rear, better replace both the same brand, I found that Sach tend to be lower than BOGE and personally Iike BOGE more than SACH.
11) replace lh front window lifter..already got weird noise while going up and down.
12) T/shoot air cold very cold especially at night..
13) diy angel eyes or might jus give the shop techs to do it. -> DIY should be an easy task, just google around and forum like e46fannatic or bimmerforums have lot's of detail info.
14) my favourite, 2 din dvd player with gps.> Never install on mine, but you may try search in Lazada, quite some choices there.
15) reverse camera> Never install on mine, but try get from Lazada,, lot's of choices with very reasonable price, maybe you can try the wireless type.
Yes..this scanner was quite useful but the price seem to be a bit high. Try to check with this seller:- http://www.priceza.com.my/s/harga/BMW-Scanner-1.4.0-Diagnostic-Scan-Interfacersdn26 said:Is this the scanner?
