my E46 M3 recently bought
hi Mel,
Congratz bro on ur new beast. Im working in Brunei (offshore) office in Kuala Belait, maybe can pay a visit or tt somewhere, since i juz bought mine ealier this year. Interested in smg software upgrading. hehe
hi qaplause,
Thank you bro. Im working onshore office in Seria and is your m3 in Brunei?
Got airbag warning light up
I scan the code
Remove the front passenger seat and clean the belt lock with contact cleaner and its associated connector
Reinstall back the seat and no more airbag warning..cheap fix
Removing the airbox wire mesh to give more airflow
Reinstall back everything but didn't feel any different, maybe a bit less fuel consumption
Replacing spark plugs
The new plug on the left
Install with a torque around 22ft/lb
Updating my ecu, smg and ASC software with Progman SSS
After the update, feel much smoother gear change and re-update it back to csl smg software as already installed gone due to the update.
Replace my heavy big size battery with bosch s5 74ah much lighter with the one before
Tried to get a set of the ngk plugs from my usual parts shop but was not available. Where did you get yours bro?
I order it online, plenty if you google it or ebay
More updates
Replace my rear trailing arm bush with whiteline product
Replace the front lower control arms with cheap chinese parts
Service the vanos unit replace the vanos seal plate
Install 1st stage macht schnell intake kit
Dyno run, seem below my expectation and sadly, they strap it on the wrong part and bend my lower rear chamber arms
continues
Lastly, change the diff axel pinion center shaft seal due to leak, part is cheap but the labor is lots of works
thanks guys, might go for another dyno soon but at different place this time.
Been longtime I haven't update my m3, current mileage is around 370k+ km and still running strong.
Guess u have been so engrossed on the M3, till u forgot abt the forum.... hahaahha.....
enjoy bro.....
