Hi all,Thought I'd update whoever is interested on the status of my 23 yrs old plaything. Originally bought from TJ on this very forum, here's what has been done to it:-Replacement of all suspension bushings and pillowballs, plus rear shock mounts-Replacement of steering rack+ repositioning (comes from an E36 and was a bit too high)-Replacement of clutch slave and fitting of a steel braided clutch hose-Replacement of rear diff oil seals-Removal of all ICE - who needs that when you got an M50 singing through a Hiop exhaust -Removal of cruise control unitIt still has an M50B25TU mated to an E36 M3 6spd gearbox, E36 M3 front brakes, as well as E36 rear disk brakes and BBS RK 17" rims. All this was skillfully fitted by TJ.In the future, It will go through a bodywork touch up, though it's not really urgent. The ABS system will probably removed at some point. Finally, I might change the final gear ratio from 3.46 to something like 3.25 or 3.15 to save some RPMs at cruising speed... With the refreshing treatment I've given it, it now is rock solid, razor sharp and pulls like a freight train through all 6 gears. I do feel like a millionnaire when I drive it, looking far ahead, past the badly cracked dashboard :-DHere's a pic of it after a wash. Will upload better ones later, this is taken from my phone...Cheers,Nico
