bobpuvan
- Oct 26, 2006
- 31
after two moths of searching finally my dream come true, i've bought 1997 e36 318i (RM 52000.00) two weeks ago in puchong- all standard eccept for the cheap pvc grey seat the use car fix. . i didnt bring any mechanic, nor sent to workshop. i test drive it the gear engages smoothly , the engine runs smoothly , and i checked the exterior for accident no sambung evident so i buy it it. now in two weeks i travelled 3500km.the engine will be running for long hours (nature of job). I'm happy with the car . what should i do next i got few question to ask u sifu's?1 ) everyday the coolant level drops by 2-3mm (around 25-30 cm in 2 weeks.) there's no sign of leekage.what could cause this ?is this normal?2 ) normally i will turn on the ignition and wait for all lights to go off and then i'll start the engine. to day the two red lights on top(both beside high beam) one light is battery and the other is showing some fuel nozzle thinngy didnt go off. but they went off once the engine is started. what should i do?3) since this is my first bmw and i've never driven a bimmer before . what should be done and where should i go?because i travel alot i want the car to be in good condition,i dont want sudden problem happen while i'm driving in and old road middle of nowhere. one thing for sure both rear suspension has to be changed and all four tyres. PLEASE ADVICE. THANK YOU
