Magnesium engine
wirelessjunkie
Is it true that there are many instances of the E60 525i magnesium engine going kaboom? Need to gather info before taking the plunge :)
haven't heard of it...you realize the whole block is not magnesium. Everybody knows magnesium is combustible, that's why they have aluminum liners for the cylinders.
It's a magnesium alloy of course. what I was referring to was blown engines and cracked blocks. Heard that there were quite a few cases of that. wonder if it's a heat dispersion problem?
I have not heard much about N52 engine block failures. Its definitely news to me. Where are you getting your news/info from?
The N52 is a versatile engine used in various lines. It has aluminum cylinder liners aside from the magnesium/aluminum alloy block. I don't think heat dispersion will be a major issue with them, certainly not to a point where widespread failure is occuring. BMW depends on these engines a lot and have engineered them as such.
The hot and humid climate here in Malaysia can definitely be a huge stress test for the engine to endure.
Have not heard about any failure so far but I won't be surprised there are. It's a new technology and countless of testing in controlled environments can't replace real-life test in the long run.
The 3 cases you know of could be hydrolock related.. due to the rains and floods we are seeing here lately.
Otherwise, the N52 has had a clean record in terms of major problems as far as I know.
Never heard of anything like that so far, except happy owners :)
I think BMW has tested the engine extensively, in the desert and such. To manufacture this block, a new whole production process is employed. The only thing could be the quality control when the block is casted. As we know, magnesium as a metal is brittle, perhaps even with the inclusion of some other metals, its still brittle and prone to cracks??
wow.. blown engines.. better be careful, dun buy one, then kaboom..
Puss in the boots - Speaking from experience, izzit?:rolleyes:
WJ - Nope, have not come across any news of N52 engines going kaboom, yet.:eek: The 3 cases you know of, are they fellow forummers?:confused:
