///M Engine Oil Service Pack
Go 0w-30, confirm good oil pressure, can pancut far far! :D
How come Fully Synthetic Edge Sport is Group III oil? Like that how to fight with Group IV TWS? Mineral oil break down faster le.. Even Torco 100% Synthetic also better than Edge Sport nia.. Torco is Group III+.. :D Cross blend.. :p
t2ribena;498029 said:
Firstly, i did not blame it on the oil, i was merely stating in reply to your claim that the bearing can also get damaged eventhough it is on TWS as per your statement that if you do not use TWS you will have problem with oil pressure and scuffing mark on bearing...
improper installation, inaccurate bearing? these are factory fitted by BMW and failed at >100000km...if those improper and inaccurate things you mentioned is correct then the bearing will be destroyed sooner than 50000km...failure of oil pump would cause much more damage than the bearing alone...no?
Yes. A total failure of oil pump will cause damages more than the bearings alone but a weak oil pump will gradually cause failure on various parts of an engine and yes, manufacturers have their own failures too.
why not enlighten us with your oil pressure defination? how that the TWS affects the oil pressure than other oil and in this case the Castrol Edge Sport which has the same viscosity but of type IV and III oil respectively?
I wont say TWS will not cause any engine failures but a well selected engine oil is definitely better than a random selected oil. A good oil holds its viscosity index. It holds a stable oil pressure and oil temp at all rpms. Ive tried and experience what minor and major oil pump failure was and what is a well selected oil and a random selected oil. Although I might be selling TWS but my preference would always be Motul 300v Series.
We can go on all day on this thread. Likesaid its your choice and your decision to make. It doesnt bother me. I am just selling what BMW is selling. Maybe at a fraction of its price =)
Cheers!
Anyway, I guess IV is better than III.
Its all very well written. Better = pricier? Lol!
Cheers again!
GT35R_BMW;497936 said:
Guys,
Oil temp doesnt really concern me.
Have you check out the oil pressure during hard driving between the two oils or scuffing marks on bearings after 100,000kms?
Oils will be oils..Most oil works on most cars and what you pay is what you get.
Like said. You wanna be economical and you wanna drive a high performance car its up to you.
These TWS were recommended, sold and imported directly from BMW USA. If you wanna doubt the manufacturers of your own vehicle its your call.
Cheers to all!
First of all in BMW's higher powered cars, there is always an oil temp. That itself speaks volume of its importance. What if there is an oil pressure gauge, is it more important than oil temp gauge? Pressure gauge will only show me the oil pump is working, but it won't tell the state of the engine.
To reply your question on the oil pressure, could you share with us what is the difference in oil pressure between TWS and EDGE Sport? Do you have any data or are you just posing a question to me?
If its the latter, this is what I learned in fluid dynamics....from the density of the oil (check the info I provided earlier), the EDGE Sport (despite rated at 30C) has similar density to the TWS (rated at 15C). As a matter of fact, oil will become denser when its temperature is lower. I do not have the information here, but suffice to say there is great likelihood that Edge Sport will have similar density, if not higher than TWS at 15C.
In layman's term, it means when 2 objects with similar density is compressed, the pressure should be more or less similar. The experiment done in school those days was to put oil, water, or air in a syringe with one end blocked, and the push the plunger on the end.
Water with a density of close to 0.995 at room temp (30C) is practically impossible to be compressed, where as air with a density of 0.0012 at 20C is easily compressible.
Now you mentioned this "Less oil pressure = more friction = more heat", getting into thermodynamics :)
To me this statement is very misleading as lesser oil pressure doesn't cause more friction in some cases which then generates more heat. Lesser oil pressure will generate more heat for sure because of heat soaking, meaning to say the oil circulation is slower and hence the heat rejection rate via the oil cooler and oil sump is slower.
Imagine of an engine bottom end filled up with oil to the brim for discussion sake, the conrod and bearing soaked in oil. Oil pressure is more or less zero with the pump disengaged, is there more friction, or lesser friction? If friction is the same with the pump running, why does the temp go up? One can then safely conclude the temp goes up due to heat soaking.
As for scuffing on the bearings, irrespective of what oil you used, if its not changed regularly and becomes contaminated, scuffing will occur. There is no evidence that TWS will lessen bearing wear compared to EDGE sport, and as t2ribena has shared, scuffing do also happened with engines filled with TWS.
Yes, you get what you paid for and in this case the main difference is the Group 3 and 4 oil base and that probably explain the marginal improvement in terms of boiling temperature, which to me is important. Then again, when my oil temp hits 125C on the track, I usually will ease off and upshift at a lower rpm. If anyone is insane enough to test the boiling temp of the oil, chances are the engine would have seized before he/she reached the boiling temp of the edge sport, let alone the TWS.
No one is doubting the manufacturer's recommendation and TWS is not the only oil specified for usage in the M cars. The formula RS which is superceded by the Edge Sport is also approved for usage, and Castrol themselves has confirmed this with me via email.
Cheers
Cheers!
Dude you have not answered your own question in terms of oil pressure between Edge sport and TWS, more so as you have proclaimed it to be of your utmost concern and one of your performance barometers.
Cheers
GTR35,
Read the classified rules. Commercial sales are not allowed in this forum.
Your thread will be removed.
Cheers
Hi Albundy,
I was strictly obeying the forum rules. The thread was started with a statement of "limited amount supplies"
I could have purchase extra bottle of oils for my own M car and i decided on selling them. I dont think it is related to any commercial posting.
Cheers!
GT35R_BMW;498248 said:
Hi Albundy,
I could have purchase extra bottle of oils for my own M car and i decided on selling them. I dont think it is related to commercial posting.
Cheers!
Come to Official TT and show us your ///M :)
Cheers
Is this forum solely for bragging?? Lol!
Sorry.. car was sold thats why im deciding to sell the oils..
Cheers!
Now your ///M is sold :rolleyes:
Anyway decision is made. Please abide by forum rules.
Further infraction may cause your usage in this forum to be suspended.
You are warned.
Cheers
Albundy,
I am wondering how were you elected as a president if you handle things in such unfair manner.
Even a personal posting is deleted. Would appreciate if you could bring up my last thread that Ive posted on classifieds and point out the statements as a commercial sales.
Cheers!
Kevin,
I have done a search on all your postings in this forum.
I am more than convinced most of your sales are commercial in nature, if not all.
Active Autowerke? Vortech Supercharger? Bilstein Kits? 5W-40? Top head gaskets?
And much more....and as a BMW community here, we appreciate honest folks and not someone that mocked our intelligence.
The onus is on you to prove otherwise.
Cheers
I dont think I have ever been reported with any dishonest sales so far Albundy.
Please reconsider your statement.
Anyway like you said. Its a community forum. Not someone who abuses his capability as a president. Bottomline its your call and your forum. Hope this forums stays in good hands.
Cheers to all!
Proclaiming me of abuse, without substantiating any proofs will not win you any argument.
I am not saying you are being dishonest but stop mocking our intelligence by saying it is a private sale, or how you ordered extra oil for your ///M car, when your past postings have overwhelmingly showed the nature of your business.
Again I reiterate, the onus is on you to prove otherwise.
Fair enough? :)
Cheers
Support our President! Long Live! *hint :D :D
The forum never been in better hands then now.. :top:
GT35R! We heard u, we appreciate your offer.. still RM85/Lx4 = RM340/4L.. The Edge 5w-40 is retailing at about RM180/4L and I bought my SLX Powerflow 0w-30 at RM198/4L..and I'm pretty sure the Edge Sport is about the same price, confirm not exceeding RM300/4L. If using Formula RS or Edge Sport will result in overhauling the engine, let it be.. its their //M, not yours! They have been warned! by u! :D
Those who need your TWS, surely will PM u.. let's agree to disagree to whatever conflict in opinions there is.
U have a problem with our President? Paid up RM300 and become an official member, then vote for a "better" President.. or better still volunteer yourself if you think u can do a better job!
:wink:
Cheers to all!
bro, I take offense of your claim that albundy of abusing his power.
I have just read thru all your postings and I can say what most of your postings are "sales" related except for this thread about the tws oil.
This thread is also about his oil sales, where the link to the classified is posted on the very first post on this thread.
Again, it is up to him to prove otherwise.
Hi Albundy,
Cheers!
when u sell something and make profit even if it is rm0.10 it is considered commercial...limited does not grant you special treatment...
normally in private sale u loose money...u buy something for rm100 then u sell rm85 then thats private sale...hehe
his ///M is sold and do you know who is the buyer....... it's ME.... i have bought his ///M.... yahoooo...
