KONMEI TIME ATTACK 4TH MAY 2014 RULES & REGULATIONS
GENERAL INFORMATION:
Entrance fee is RM180.00 for 1 category, including Konmei Time Attack 2014 T-shirt.
The competition is divided into 5 categories as per below:
Category A : 1300 and below
Category B : 1500 cc and 1600 cc
Category C :1800 cc and 2000 cc
Category Open : 2001 cc and above
Category Special : Car club min 8 car
• For all VTEC, MIVEC, DVVT, or similar technology it will go one category up from current cc - for example MIVEC 1.6 cc will be in the 1.8cc category, engine proton cps it will by voting by participant on briefing time.
• All lighten body, stripped interior and anything similar to that will be in the Open Category - this will all base on scrutineer’s and organizer’s result to be in which category.
• For forced induction car. Supercharged’s car displacement will x 1.5, turbocharged’s car displacement will x 1.7 (for example Turbocharged Proton Wira 1489 cc (1.5) x 1.7 = 2531.3 (automatically in the open category)
• Regardless of any category, all cars in are allowed to ONLY remove the rear seat
• All vehicles must have current road registration EXCEPT open category.
PARTICIPANT’S SAFETY
• Participant must wear helmet in the track
• Participant must wear long pants or race suit is highly recommended
• Participant must wear appropriate racing shoe or sport shoe
• Participant must wear seatbelt or 4-point/6-point harness
VEHICLE MODIFICATION
• For cars with fiber body parts and plastic window automatically will be in Open category (Except for Fiber Bonnet)
• Open Wheel Vehicle, Clubman or Kit Cars allowed in open category only
• Chassis reinforcement bar and bolt on roll cage is allowed
• No limit on Engine’s modification
TRANSMISSION
• All transmission modifications are allowed EXCEPT in situations where the mount points are deemed dangerously modified or there are leakages found
SUSPENSION
• OEM suspension mount points must be utilized
• Coil Over suspension kits are permitted
• Aftermarket suspension arms are permitted
BRAKES
Brake modifications are free with the following exceptions:
• OEM mount points must be utilized
• Brake fluids must be properly filled to appropriate levels. Or risk non-entry by Organizers
• Ensure all brake lines are in good order to prevent leakage
TYRES
All Category except open category must run on tyres with a UTQG rating equal to 140 treadwear or higher rating. Any tyre which does not meet the UTQG ‘s rating is deemed as Semi Slick tyres which will automaticly to open category.
Below are list of tyres not allowed in the race :-
• Yokohama Advan A048, A050R or similar
• Bridgestone RE540S, RE55, RE-11S or similar
• Federal FZ201, FZ202
• Kumho Ecsta V700, V70A or similar
• Achilles 123S
• Michelin Pilot Sport Cup or similar
• Silverstone FTZ sport tyre RR, S575, S585 or similar
• Toyo Proxes RA-1, Proxes R888, Trampio
• Hankook Ventus Z221
• Nitto NT01
11. Many more
WHEELS
• Wheels size are unrestricted
INTERIOR
• Category A,B & C interior must remain as factory’s specification
• Both front seats must remain, bucket seat is recommended.
• Rear seat is removable
• Carpet must remain as factory’s specification
• Air conditioning must remain
17. Special category for interior is set by own car club
VEHICLE SAFETY
• Fire extinguisher up to 1kg that is safely secured in the interior is highly recommended
• All car must have working condition seat belt.A 4-point or 6-point harness belt is highly recommended
• Headlight, brake lights and signals on the car must be in working condition
• Battery must be clamped firmly
• No loose object inside the car
OPEN CATEGORY
• For cars with fiber bodyparts and plastic window
• Front seat, rear seat and carpet are removable
• No Tyres restriction
SCRUTINEERING REQUIREMENTS
All vehicles must comply with the following regulations:
• All headlights and brake lights must be operational at ALL times
• All loose objects are to be removed from the car
• The battery is to be firmly clamped
• All Vehicles must be equipped with a minimum mid mounted brake light in the rear windscreen or factory fitted brake lights working
• Any camera/video recorder attached to the automobile must be securely mounted to
• The vehicle with approved brackets by the Chief Scrutineer
• Vehicles fitted with a driver-operable reverse gear
• Competition numbers are to be written/sticker on driver side.
• All vehicles must be fitted with towing hooks or a similar device both front & rear to
• Allow for the speedy removal of a vehicle from a “sand trap” or removal from the
• Circuit in the case of a mechanical failure
RACER’S SCRUTINEERING AT CIRCUIT
Start Time: 8am Sunday 4th may 2014, Finish Time 9am for Time Attack participants.
Note: The driver must attend scrutineering process personally so that their driving apparel can be checked.
DRIVERS’ BRIEFING
The briefing will be compulsory and will be held at 9.30am for Time Attack participants AND 6:00pm for Open Track participants on Sunday 4th May 2014 in a venue on track to be advised. It is compulsory for ALL Drivers to attend. Scrutineering process will cease whilst the Drivers’ Briefing is in progress. A Driver sign-on sheet must be completed by all Drivers to prove Briefing attendance, failure to sign on will result in penalties being applied by the Clerk of Course of the Meeting
PASSENGERS
Passengers are only permitted if they have been approved by the Clerk of Course and are only permitted in vehicles that the Clerk of Course has approved. Passengers are permitted in the open track session ONLY.
• Passengers and drivers MUST wear appropriate clothing which includes long pants. Closed shoes are to be worn, no thongs or sneakers
• All vehicles must comply with the relevant discipline Standing Regulations and be fitted with all appropriate safety equipment, including seats and harnesses, which must be worn at all times by the passenger while in the car
• Persons under the age of 18 years may be passengers only at the discretion of the organizers for safety purpose. In all cases, for passengers under the age of 18, a parent or legal guardian must provide approval
• No competition driving may take place. The vehicle must be kept to significantly less than competition speeds
FEES REFUND
• No Refund for cancellation once register (Replacement of participant is allowed)
DISCLAIMER
A disclaimer has been prepared for Passengers in Vehicles. This disclaimer covers all passenger in vehicle activity, whether it be a promotional day, gift or prize.
A verbal warning will be given at the time the indemnity is signed.
Event Registration Form: (please click link below)
http://bit.ly/1jSrrG8
