Installing Bluetooth program
QME7555
Sifus,I just check on my bimmer and when tune to the communication, there nothing there. Can I install the bluetooth program on it. If can, when do I get them.
Did you use the "MENU" button to get to communication? If yes then you are doing it wrong.
Press the dial downward to get to communication/bluetooth function. You can paired your bluetooth headset from there. Hope this help.
Does your CID Display Blue tooth,If not do use OPS programmer to retrofit your CCC
