I think I have DME EWS problem...
penasenja
I drive E39, 523i Double Vanos... Suddently my car lost power, and after a while, it turn to normal again. This happen many times while im driving regardless fast or slow. Well, after checking with computer, it shows that the DME EWS appeared to be fault. Anyone experience this before and anyone can give me idea what cost that i am facing now? uhuhuhuhuhp/s: not a good start for 2013
Ur problem seems like not related to EWS. If error log shown ews it could be key problem which log previously. It could be ur DME having problem. Pls meet me to scan ur car first.
My hp number is 016 395 3826. Whatsapp is 014 938 6599. Call me at night or whatsapp me anytime.
@tweiboon
bro i have the same symptoms too but my error is different "trans failsafe prog" appear on my dash...any idea?
pena senja stays in penang. perhaps bro aidilj can assit?
Didn't know pena senja is from penang. Contact me if needed, cheers!
Bro Yazmeen, how is the error cancelling going?
mika;796947 said:
@tweiboon
trans failsafe prog meaning transmission facing problem. It can be ur gear box or transmission board having problem.
Not really. Low current or battery will engage the same error, sometimes either battery or alternator is dying.
Thanks Tweiboon. Yes, Im in Penang. Bro Aidilj, macam mana nak contact u? Btw, I 've check the air mass as well, but it seem okay, the trottle body also got no problem. I guessing that might be cause by Fuel Pump, i really dont know... Anyway, Tweiboon is also correct about my key's problem as it is not functioning (the remote) quite long time ago, but the car runs perfectly all this while. It could be DME. If it is, can it be replaced? or do i need to replace the whole set of DME EWS system? Look fwd from Aidilj's contact.
Thanks.
Thanks.
My hp number is 016 395 3826. Whatsapp 014 938 6599. Replace DME no need replace EWS. New DME can pairs to ur current DME with special tools. CNY i come to Sungai Petani. If u want to meet me in CNY at Sungai Petani.
At last, problem solved. Lucky that only fuel pump seem to be fault cause some wiring failure (that what my mechanic told).Due to that, one float need to be changed as well. My car back on track again... thanks for all support. One more lesson learned.
Thanks for sharing bro... Glad your car is back
Didnt know u are my kampung boy also .nanti jgn lupa bawa balik kuih bakul
Shiva, r u from SP as well? haywire and me also from SP haha
May I add .. it might be related to ABS Module too... cause it happened to me @-@
