E39 asc & abs light on will shut engine down or not?
hi bro,the wire putus can diagnosed or your mech troubleshoot it him self? which w.shop you go ?your mech really done a good job for you ,cheers !
bro,
ive read in the matsalleh forum if the abs indicator liteup without the triagle, its the front speedsensor.
if the abs indicator liteup with the triagle indicator, its the rear speed sensor failure.
next you hv to manually check wic sensor giving u problem left or rite side depending on the sypmtom above.. normally its just as broken wire as the sensor wire aging(wear n tear) like in my case.
my e39 was in kuantan wen it happen. the mech told my wife tht the wire broken and want rm330 for new sensor. i told my wife to ask the mech to rewire the sensor.the guy solder the new wires, tape it. and installed. pretty decent job on my inspection during the weekn.
1)The 'check engine oil level' light on
the workshop changed another engine oil level sensor OEM brand HELLA ,channged new engine oil for me "FOC" ,the 'check engine oil level' signal gone,so far so good
2)the asc and abs light on
confirmed is the asc module faulty,because after fix a new module on it, the asc & abs lights go off,so fix a new original bmw cause RM1800
3)when the rpm going down to about 1k rpm my engine shut down with all the light still on(battery still supply in) ,i push gear to N swithoff the engine and swith on again,luckily the engine can restart ,this happen few times since two weeks ago
my car engine not stalling any more since that day incident untill now,so this problem still not solved yet,
thanks bros for all the response and help
CHEERS ........
