Finally, i able to clone the key and start the car. To clone the key I must unplug EWS from the car due. The clone key machine that I have is the cheaper 1 that is why needed to unplug the EWS.EWS located at behind the small drawer at the bottom of the Headlight Switch. You able to find the OBD connector inside this small drawer too.The clone key machine need to connect to the EWS module in order to clone the key. I found that used transponder cannot be rewrite again meaning for this clonning process you must use a new transponder to clone a key.You all now no need to clone the key with super expensive pay. I can offer the service already.
