sewell
- Dec 7, 2009
- 632
- 18
3er;728648 said:Got any for E90?
we are planning for group buy in the future. waiting for the price list and tax calculate from the forwarder. please stay tune into this thread
i don't quite get what u mean. for u is proRs or goodridge better?hky;731004 said:I used ProRS before, this is much better.
pussy;731092 said:![]()
bro, can i know what's the reason you use DOT3 brake oil, instead of DOT4 ?
B33mEr;730958 said:Nice upgrade bro :top: I'm on Pro-RS for 3+ yrs already so far so good hehehe PM me the price for E46 am curious to know :4:
What is the lifespan for the goodridge?
sewell;731153 said:There is not so much different between DOT 3 and DOT 4.
QUOTE]
sewell,
DOT 4 handles higher heat and e39 service manual specifically state that DOT 4 is to be used. So in another words, BMW does not feel comfortable that the braking system will not raise the brake fluid above a temperature that DOT 3 can handle. You can put DOT 4 in place of DOT 3 and not the other way round.
Herbert;731162 said:sewell;731153 said:There is not so much different between DOT 3 and DOT 4.
QUOTE]
sewell,
Mr.Hebert,
lots of the brand outside who advertise DOT4 are actually DOT3 for the brand what i am using. as for your information. my DOT3 is in white color. not that you found outside DOT 3 red in color.
huskar3399;731105 said:i don't quite get what u mean. for u is proRs or goodridge better?
hky;731167 said:Sorrry, I mean Goodridge is better, much much better
pussy;731229 said:Dot 4 is a for higher boiling point means better brake feel during hard/long drives which requires less brake fade.
example, DOT 3 has lesser boiling point, means more brake fade after a few laps in the track, whereas DOT 4 or higher will have less brake fade.
By the way, BMW brake seals at the calipers are made to take DOT4 above and resistance movement of seals of the Master Cylinder is based on DOT4, not DOT3.
Yes, DOT 3 and DOT4 colour does not mean anything.
bmw7833;731336 said:What is the diff price?
sewell;731253 said:bro pussy,
refer to the chart of the DOT3 and DOT4 i uploaded abover
DOT 3 requirement wet boiling point require from JIS min140'c where the product DOT3 score 154'c ( which only 1'c lower than DOT4 requirement from JIS)
dry boiling point require from JIS min205'c where the product DOT3 score 254'c ( which is exceeded DOT4 requirement from JIS)
Refer to DOT 4 requirement from JIS wet boiling point from JIS standard is min 155'c and dry boiling point is 230'c
so i am sure that this Showa DOT3 brake fluid can fufill the needs of our BMW requirement.
