Here comes my brake !!!
koreng
Valentines Guyz,Okay, got e problem with my brakes. was doing 80km/h, then suddenly pressed the brake, was pressing with no preasure. why is that?Parked my car, checked d brake oil, is in d max level. am i looking at the cylinder problem?brake pad?and g'wut, brake indicator lights up. still, have no idea. Help from u experts?please. many thanks
check your vacuum hose to the master pump, make sure all the clips are thigh. if you are still using the original factory clamp, replace them with the screw on type. if the vacuum is leaking or non existence, the sensor at the master pump will light up the brake indicator lamp.
get it fixed fast, be EXTRA careful when you are at a start and stop traffic, thats when you are most likely going to encounter any sudden brake usage. had the same problem last year, required a major nose job after kissing a pajero's ass.
Jules;195565 said:
straight to the mechanic if u ask me.
Yeah, please don't drive it until you fix the problem. With faulty brakes you endangering yourself and worst still other road user! Have a safe, happy CNY break, not a sad one.
Thanks
Many thanks guyz. Very thoughtful of u. thanks thanks. i shall give u guyz limau !!more limau !!!
