Try this thread.. see post 26.. at this thread.
http://www.bmwclubmalaysia.com/forums/e36-gear-box-t8678p3.html
Bro jarance,jarance said:Did you see the vane come back when you peep?
Ahh.. If the idling speed is OK at N or P position, I don't think the problem could be due to the AFM or the ICV.
Please check the gear selection switch. Sometime this worn out contact on the gear selection switch would also cause the problem. You can inspect this switch condition by removing the cover of the gearshift. It only cost you about RM180 to change this switch if it is faulty or worn out.
BTW, this switch failure also cannot be diagnose with modic. Only a very experience mechanic can know this when he/she test drive the car.. You should considered seriously to change your mechanic. Look up the List of workshop that is used by other forummers.
As the automatic have been rebuilt, I sure the filter and the AFT have been changed. So it unlikely to be the cause of the tranny to fail or malfunction. Failure of solenoid for the gearbox is also monitored and registered as alarm.
nathan said:this morning my idling started its tricks again............
i think time to change the icv (or in other words time to get my pocket burned)
but first i think will take it to the makanik to clean it first and see.....
by any chance we can do it ourself????
thks guys..........was just saving money to change to the multi function strearing wheel and now this blady thing cropped up........realy pissed
aiyo, cheap lar 600, where u change it and what brand?mizuan said:Nathan,
Find a good mechanic to clean the ICV for you. In my case DIY is a bit of a problem because with the M40 engine, you need to take the manifold out of the way before you can reach the ICV. In my case the ICV went caput after paying RM75 for the cleaning job. It didn't happen at the workshop but immediately the night after. The ICV just jammed and I end up paying RM600 for a new one.
Good Luck
if u dun wanna burn your pocket very easy, step on the gas pedal and start your car, sure can work. i did that for few monthnathan said:Hi Mizuan,
thanks forthe advise man.........yalah will take the car in...just that very busy this few days.........
hopefully cleanning will solve the problem
Mouse said:aiyo, cheap lar 600, where u change it and what brand?
geoffreylee;212292 said:Where to have my ICV and TB cleaned? Some say it only cost RM50.
mizuan;212314 said:I did it at BMWSpecialist Batu Caves. Unfortunately it went caput after the job and I have to change to a new one. Its not the fault of the mech as I have been warned before he took it out. Just make sure that its the ICV that is the problem not other things. In my case its the latter. I thought of saving a few bucks by tryin out cleanin the ICV but ended up worst.
BTW, I dont remember how much but I think it costs about RM50 to do the job.
Good luck. Remember the ICV price has gone up.
geoffreylee;212338 said:Thanks so much for the feedback...
Does this mean we should not have the ICV clean or risk for it to go Kaput!!??
Haiyo..
