Helpp - from minor to major , really bad luck
tomspc
my e30 died while driving and so push to one sidecalled the mechanic - he check the fuel , okthen check the ignition coilsaid no sparkokleft it to him sort it outlater got a call from himsaid engine is really gone case - ?????apparently he put back the ignition coil, changed the distributorcap and tried to start itstarted awhileand according to him the timing belt broke and now engine is write offomgbrothers is this true or am i being ripped offassuming the engine started and then the belt brokeis it possible to just change the belt and stuffI still cant belief that from just cant start enginenow become wirte offsigh - have i offended the gods
There is no way for the car to start if the belt is broken for an M40 engine.
If there is no spark, the problem could be the crankshaft sensor.
ask coupe e30 about his luck... driving to the workshop to do the timing belt, the belt putus...
why dun you inspect the engine, ask the mechanic to open up the belt cover to see if the belt really putus..
really feel for you bro..
what if
the mechanice said it started a while after he changed the distributor cap
now wat if
he had plugged in the plug cords in wrong order
will this cause the timing belt to break
i wonder
if this screw up due to the mechanic
now wat if
i wonder
If the mechanic plug in the wrong HT leads, the engine would be firing on 2 out out 4. That means the engine rev would be very eratic.
As mention by pussy, the timing belt can easily checked by open the cover near the distribution cap.
If your timing belt is broken, the crankshaft will not rotate in proper sequence. The crankshaft sensor would not be able to detect the TDC and will inhibit the firing of the spark plugs and also the fuel pump. This is a fail safe feature to prevent further damage to your piston and valves.
If the timing belt break while the engine is running, chances is that you may have a couple of bend valves or worst piston kaput.
Best option is to do top overhaul.
e30 timing belt
looking at the option of whole engine replacement
fount online a e30 engine for $800
mmm
wat do u think guys
the mechanice quote the overhaul plus repairs 1K plus
so if just replace whole engine - better ya
the engine now is also a recent replacement
mmm
should i plonk in a 325 engine ;p
mmm
wat do u think guys
mmm
Yes please!!! :love: :top:
timing belt
had another mechanic open up the cover and see the belt
not putus - however could be the - wat u call it
teeth of the belt worn out
so
looks like have to tow it to workshop
put in a new engine
overhaul top end - y so xpensive ah
all quote more than 1k
put in a replacement engine is cheaper
so
put in a new engine
Why do you have to do top overhaul if your engine did NOT experience Over Heating or Timing Belt Snapping while driving. I think you better get a third opinion from a mechanic who have work on a BMW before.:eek:
so it's not your mechanic's fault...
if i was you, i will do a top overhaul, cos the spare engine which you buy is like a lottery, dun know after the 1 week warranty, the engine will last for how long..
cheers..
e30 timing belt
thansk for all the advise
went to view a e30 engine kosong
however not sure its the correct one or not
are there many versions ?
don wanna buy wrong one
was quoted 2k for a e36 complet engine ??
ok
back to reality
just wanna get the car back to running
at minimal cost
;p
now which workshop to tow it to
aiyaaa
how to decide
why you want to buy a e36 engine, when it will cost you at least 15k to mod it in.
aiya, if really need help, send a sos to me or RB. we meet up, see your car then will advise you from there..so easy..
psst.... no budget ka ?
regards.
ok
back to reality
at minimal cost
;p
aiyaaa
how to decide
bro, come to this friday TT and talk to pussy. I promise you that he wont bite you.
He have help me before when I have engine trouble..
