leforte;389970 said:
its still a ssg by any name you called it. it works differently and the hardware is entirely differen. stupid bmw ag. confusing the masses. sigh....
beemer, the ssg gearbox is made by MM as well. and it was never a standalone manual unit from the start. unlike previous smg boxes which is basically a manual getrag unit with retrofited smg controls.
YellowMellow;390007 said:
again youre rite bro.. :top:
Logically it wouldn't make much economic sense to have a small niche volume of SMG gearbox rather than have a mass volume gearbox and adapted to a electronically controlled hydraulic actuated system cos it would be too expensive. If that was the case then SMG or SSG wouldn't be so problematic mate .... Mine is a 5 speed getrag unit GS5S31BZ according to realoem.com
Also i've been searching for a magnetti marelli gearbox for BMW ... it seems that i can't find it ...
http://www.magnetimarelli.com/english/powertrain_prodotti.php
An "excerpt" from MM website
TRASMISSION CONTROL
Magneti Marelli Powertrain produces robotized transmission gear or AMT (Automated Manual Transmission), that consist of the
transformation of a regular gear box where the manual transmission is replaced by an Actuation kit (plug-in) electronically controlled by a Transmission Control Unit (TCU)
This system allows:
* Automatic gear shift
* Automatic clutch
In this way the driver has the following options:
Possibility to choose between manual or automatic transmission
Manual transmission by joystick or at the wheel
No more clutch pedal
In addition all the information can be displayed on the dash board for a deeper awareness of the driver.
Again i cant find any mention of gearbox (if any) made by magnetti marelli for BMW except for the electronic transmission control or AMT .
Even M3 SMG2 uses the same gearbox as found on the regular manual M3 ... i didn't know Siemens made gearbox too
Anyway here's an excerpt from BMW pdf document explaining SMG for their technical staff
System Components
The SMG II system is consists of the following components:
• Basic Gearbox (S6S420G, Getrag type D)
• SMG II Control Unit (Siemens)
• SMG CAN Bus
• DME Control Unit (MSS54)
• Hydraulic unit and solenoids
• Gearbox Actuator
• Clutch Slave Cylinder with PLCD (Permanent Linear Contactless Displacement)
• Shift Lever Module with Shift Lock
• Steering Wheel Paddle mounted switches
• DRIVELOGIC Control
• Display in instrument cluster
• DSC control unit
• SAC dry single disc clutch
