Help on my car modification ! help pls
jeffreychung
Hi to all experts here ! ! I am currently driving a E46 325i for the passed one and a half year . I plan to modified it and i saw many E46 in Penang having wide body !(Damn Cool) . . jus wana be like one of them ! but i have no confidence at all . I am not sure whether after modified and my car turn bad and is not as smooth as now ! the shop reccommand me to use spacer - 19/265-275/30 for rear rim and typefront - 19/235-255/35...Spring booster for more powerfull pick up .TO all the experts here please leave me comments on whether the widebody modification will take and negative effects on my car . . . THANKS . . .
Must be done carefully and tastefully for best results... could be quite expensive if you go to the wrong people. You have any idea where to do in Penang? Get a few quotes and compare... possibly good to compare with KL prices. Have the fender knocked (metal work) instead of using fiber flares. Change your wheels first before starting the job so there won't be any rubbing issues later, especially when you turn the wheels fully. You can either use spacers with 3 series rims or use M5 rims for better effect, depending how much you plan to offset the wheels out. Print out pictures of your favourite widebody car and plan carefully with your body work guy. It is very difficult, if not impossible, to roll back to original look but personally I love the widebody look on e46 and I'm sure you will be quite happy with the outcome. Good luck!
