Jedcoyxiicut
- Apr 5, 2010
- 47
Hi Guys need your opinion on this matter. Presently my car runs 18" rims with 225/40/R18 Fronts and 255/35/R18 rears. I am planning to upgrade it o 19" rims. I understand that orginal BMW 19" for Z4 are Front 225/35/R19 and 255/30/R19 Rear. This size is fine as the original rims are 19X8 front and 19X9 rears. The rims I plan to get is 19X8.5 Fronts and 19X9.5 Rears hence the size would need to be changed slightly. I was advised to use 235/35/R19 for fronts and 265/30/R19 rears.. However after reading feedbacks i understand that the ride will be harsher. Is there any chance will a 235/40/R19 front and 265/35/R19 fit using a 19X8.5 front offset 35 and 19X9.5 rear offset 45? I do know the speed will be off greater but would like to know will the size fit as I do not want to sacrifise the ride comfort of the present setup? Thanks!
