HELP!exhaust white smog like mad after service
dungbtle
bros, this is the scenario, my exhaust is emitting white smoke that is thicker than those fogging things u spray for treating aedes nyamuk! what happened was, my petrol consumption is high, so i sent my car for tuning of the co , and found out that my oil sump cracked. so the mech had the oil sump welded and put back, and did some other normal services and replacing one of the air hoses(cracked) .. then i drove it back happily althou my petrol consumption problem has not been solved. but the next morning i started my car, there were white smog thicker than i could ever imagine coming out. car start with one crank.but the emissions were terriblly choking smelly. so i thought it was condensation, and i tried later at nite, its still the same.the next morning, its still the same. 3 mornings later here i am. confused. ... after a while when the car is heated up, the smoke is not so visible .but there's still there.the bad fumes are all the time being emitted.some tell me that it might be my valves, some say its my piston ring. some say it might be lean mixture. but before my service, it wasnt as bad. atleast no white smog. whats worst, and now. there's a "whirring" sound from my engine as if something is grinding inside... goDdddd!!!!! help me, or atleast send some forummers to give some advices. hahah cheers.
check where your mech &uck up... maybe the hose is loose, forgot to install the pick up pipe back, pump going bongkers...
yeah the true engine master has spoken yeeeeeeeeeehhhhhhhhhaaaaaaaaaaa
