TheNemesis
- Mar 13, 2011
- 96
now my current doubt will be auto or manual? do give suggestion and what to take note?thanks !
TheNemesis;616589 said:but cheaper leh if overseas one.
JediM;616876 said:Without M suspension I believe you would not be getting the most out of what the engine can provide in terms of JOY...
JediM;617072 said:If you're thinking about the grey imports, ie recon car, you need to check on the engine specification as well. Personally, i think there's too much technical risk with a recon model of the 320D. in the long run, the saving you make from a cheaper purchase price might be given back if you end up with mechanical/electrical problems that need to be sorted out without the coverage of warranty and guarantees.
TheNemesis;617183 said:wat u meant grey importers?
docrayboy;617461 said:'Privileged' car companies with lots of APs......
MRA;617752 said:Does the local diesel (euro 2) cause any probs to the engine and performance of the car? Will there be black smoke in the exhaust emission in the long run? I'm keen of getting a 320D as well, but worried with the fuel standard which is far below the grade used in europe and US....any advice is appreciated.....
