Group Buy: Multifunction headunit for DVD, TV, GPS, Bluetooth, iPod
Anyone encountred qa problem where when tyou switch the right signal and press the brake, the camera activates intermittently following the flashing of the signal?? if you just use the signal or the brake, no problem but when both are pressed simultaneously, it happens...pls adv..
Wiring problem bro..I think u connect something wrong when u replaced the reverse camera recently (if u did).
Is this happen since the 1st day u installed the reverse cam? I stil feel that is the wiring problem which u may tab the brake line or signal line. No harm to have a check bro.
* A quick check, the reverse cam power come from left or right light?
Installation for e92.
I checked the wiring back again( unfix and fix and walla..the problem solved..maybe loose connection..btw its connected to the right light.
Hi there! Is Group Buy still on?
I am looking for unit for E90 pre-LCI.
1) Will all the function such as fuel consumption, etc be retained in view through the touch screen?
2) Will multi-function steering control still be functioning?
3) Please let me know the price for full function - TV Antenna + Reverse Camera.
Thank you.
Bro BMW 7833,
Am interested for e90 320. Pls pm me for price of head unit. Thanks!
All PM reply.
And pls leave me your contact for better communication, thanks.
