Hi all sifu,My ride had gearbox problem where warning light came out after riding about 15 - 20 minutes and will lock on to 4th gear to drive. If I switch off the engine and restart, it will back to normal for a while and back to warning light after few minutes later. Gearbox transmission is still smooth (no jerking or any). Gear oil had been change every 25,000 km. When send for diagnose, below is the message (had try out 3 times)Fault code 31 - Symptom, gear monitoringFault code 37 - Position sensor, clutchIs it the the sensor problem?
