bmwkisu;549663 said:for my case....
so, what is your advise bro Jarance?
Recond or Overhaul ? >.<
i totally have no idea for it
bmwkisu;549731 said:if i go for the option u advised,
1. change aux pump.
2. check the GB for metal filling and wear and tear.
3. Change ATF filter.
4. Use new ATF.
5. Change GB mounting.
6. Drain the ATF to the heat exchanger (radiator)
7. change oil seal.
8. inspect and clean solenoid valve, pressure regulator.
may i know what is the risk?
jarance;549672 said:If it just only the aux pump that is broken, I would ask the workshop to just do the following:-
1. change aux pump.
4. Use new ATF.
7. change oil seal.
My advise is depend on your budget. The above is the cheapest solution but you have to take some risk. I have taken the above based on the inspection and advise of the mechanic. Get a good mechanic whom you can trust. people always think that owner driving bmw are filty rich.
mkmy;549765 said:salam bro jarance
is there an easy way to determine metal filling or do we have to rely solely on the mechanic's finding?
tq/mkmy
fuad4;549770 said:You guys teruk lah :banghead:, no etiquette :musicus:, hijacked kamaldnora's posting and discussed all other problems BUT his question....:stupid:
kamaldnora;547359 said:salam/hi pada semua bimmer owner.
saya ingin berkongsi tentang masalah gear box yg saya hadapi baru2 ini. saya mempunyai masalah apabila 'warning gear box display'. tetapi kereta saya masih boleh dibawa dan gear masih berfungsi dari 1-5. cuma 'jerk' yg terlau kuat ketika gear shift. saya hantar ke sebuah bengkel dan mechanic tersebut mengatakan gear box model kereta saya tidak boleh di overhaul. katanya, mungkin akan tukar sebiji gear box. wow!!
saya tidak berpuas hati dan hantar ke bengkel yg lain. apabila dihantar ke bengkel yg kedua, baru masalah saya selesai. tidak perlu overhaul gearbox saya. di sini saya "attach" gambar part yg ditukar dan kosnya sekali.
mechanic tersebut memberitahu saya nama part ini ialah 'lever sensor'. tetapi apabila saya cuba mencari didalam 'oem catalogue' ianya tidak dujumpai. minta kepada sesiapa yg tahu nama/detail part ini untuk memberi keterangan yg lebih jelas.
kos repair :
a) lever sensor (tidak tahu nama sebenar) - rm960
b) labour charge & reset computer - rm250
total rm 1210
model kereta e46 318i n42 engine
jarance;550036 said:
bmwkisu;550471 said:finally, i go for recon GB ;(
RM 6300.00 from bayern...
bmwkisu;550856 said:just received call from Bayern, they said the recon gear box installed, but when test drive got sound from the gearbox...
now waiting KL send another recon GB ... have to wait few more days ~ bored ........-.-
