hi,im newbie here.i got probs to share.i driving 2002 318i n42 that i bought 2nd hand last year.just now ive checked the expansion tank got oil inside.anybody know what happen?otai2 plz help.
thx bro.but yeah..ive checked the engine oil cap but no 'mayo' like u said.also checked at oil level dun have 'mayo'.mayb the oil come from gearbox..?just call mech,he say mayb from gearbox.need to check for conformation.
Just to ask... ive met with a mech (just came back from denmark) i was told that all these thermostat and stuff in the radiator system can be removed in our climate since its used for CONTI-Car in Winter and such... in our country its best if the radiator can perform a continuous cooling effect... ehat the thermostat used for is to allow a certain portion of the water remain heated to avoid the water from being frozen... THEREFORE... when this fail we face overheating...
Why not just remove all those things and let the temp sensor control the speed of the fan... more free coolant movement= cooler radiator = more power to the engine = less stress on the fans...
Greetings bro, do make your self to the Newbie section and do a self intro there....:top:
As for your problem, true to wht bro haywire says, you might hv a gasket issue. Worst is you hv your cylinder cracked! Try do a simple trouble- shoot by removing your radiator cap and than try starting the engine. If water shoots out of the radiator, confirmed you have a damaged gasket. Get it replace coz it can lead to worst woes that will cost you time and money
