Dear sifu here, My E46 N42 engine found water (milky) inside engine (check engine cap ), my other trouble is keep on adding water into radiator. Lastly, I suffered to start my car when engine hot. Any solution for the problem above?Tqvm
milky engine oil means water has mixed with oil due to broken head gasket... The least is an top overhaul. But best is to do a complete engine overhaul...
A friend of mine did a top overhaul for his N42 engine at our common workshop in Cheras and it cost RM2k plus. However, the price may be lower in other places as I believe the workshop my friend & I normally uses tend to charge slightly above market rate.
