viewfinder
- Sep 9, 2005
- 598
FIR767, what was your E90 mileage when the ATF/coolant contamination happened?
How does one determine if the oil cooler is leaking (internally) or not?
Actually, how is the oil cooler constructed internally that the ATF can leak into water? Imagine radiator fins and tubes... would the tube leak? If not and the leak is on the hose connection (which has o-ring), then it's just leak out to the floor...
