Gerald 5
- Jan 29, 2008
- 691
- 18
M.Street;585491 said:TUNINGBOX VERY POPULAR IN THE EUROPE SPECIALLY DESIGN FOR BMW, AUDI/VW, M.B AND PORSCHE. ( PETROL AND DIESEL)
Tuningbox only tune for air/fuel ratio does not change ECU setting and will not harm the engine.
It is PLUG & PLAY unit with easy installation.
First lambda sondas regulate mixture, second lambdas after catalisator check that everything is within operating conditions. So if catalisators are too hot second lambda sonda will correct.
Car electronics has all protections so there is no worries that engine will be destroyed.
Digital tuningbox with adaptive power software specially designed for BMW petrol engines. ( Also available for Diesel )
Power will be felt 2000rpm to 4000rpm and above.
Increases power for +30% and up to -1.5 l /100km of lower consuption.
Eight user selectable modes between ECONOMY and POWER for complete control. ( 1 is normal setting and 8 is the powerfull )
Bigger torque in low RPM and noticable power boost in higher RPM.
All protective functions of engine remain.
Does NOT cause ENGINE malfunctions or CHECK ENGINE LIGHT.
I am in, pls advise
016-2011091
