Very rare that you would need an ATF cooler for city driving. Which E90 are you driving at the moment? Is yours the GM auto box or ZF auto box (there are 3 variants as well).DanzE90 said:Hi,
would like to ask, is it recommended to install an external ATF cooler for E90? as sometimes my gear slips in jam, suspect ATF overheat, hence the slippage,
pls advice.
thanks.
Yes that sounds like it but it can also mean that they have another type of error.DanzE90 said:mine is 2006 E90 320i, guess its the ZF gearbox.
there was once during traffic jam the gbox suddenly went into limp mode, had to restart the car then the warning signs disappeared.
wat does it mean when in limp mode? the ATF overheated?
confirm the gbox went into limp mode, it was a yellow gear sign, I then refered to the user manual.astroboy said:How does the warning sign looks like? If there were a warning sign, get the fault code. Fault code will tell you what the problem was.
Have you tried resetting the gear and then trying again? What ATF fluid did you use at the time? Did you also change the pan?Hikaru said:Any updates on this ATF overheating?
I experienced the warning (a gear symbol with a temp symbol inside - yellow) whilst I was "cruising" along at around 180km/h for about 45 minutes on the highway. Normal driving about Klang Valley is ok.
Now first to second is very jerky but i tried revving the nuts off first gear and it revs very cleanly. Am wondering is it s syncromesh issue between first and second gear? The rest of the gear no problem.
I only experience this this year after changing my ATF oil.
Yeah I face that issue as well last time (gear jerks when changing especially at low gears). After I sent my car to the BMW service to get the gearbox resetted (to be readapted again) then I barely face that issue.DanzE90 said:I also at times feel the gbox jerking.
just wondering my car suddenly dies during idling, RPM fluctuates at times...any issues?
I don't believe that the jerking gearbox is common.DanzE90 said:i was told that the best mileage to change ATF is at 40k kms, but as per your advice will change at 50k kms.
it is a common issue for gearbox jerking for e90 320i, it that true?
