E90 325 Engine Oil
fishlegs7
New Member
Dear all,
I came across this issue at my ride which is engine oil measure keep on min and unable to reset after service engine oil light.
Any idea or recommendation could assist me ?
Please and Thanks! :rofl:
Job to replace the sensor is to remove 2 screw at the oil slump and put in the sensor then tighten the screw. Plug in the socket then proceed with normal oil change... doing it when u change oil will save u the job to collect the oil and reuse the oil as you remove the sensor the oil will leak through..
Do you suggest me to change or should I change on my next service ?
I can't measure my engine oil now lol
