E46 parts & maintenance
swansonsz;798177 said:
Bukan BA ni on ss18 facing the police station on ss17 ke bro?
I stand corrected bro, yes its in ss17, i referred to the wrong map.
Heres the address
Address:No. 21, Jalan SS18/1B*47500 Subang Jaya*Selangor Darul Ehsan*Malaysia.Telephone:+603 - 5635 0000Fax:+603 - 5635 3888Email:sj@bavarian.com.my
When are you planning to change your vanos seals?
Strider74;798180 said:
I stand corrected bro, yes its in ss17, i referred to the wrong map.....
So where actually did you went to at SS14 bro...?? :69:
Heres the address
Haha just pulling your leg bro... but i have to be with bro gendong here, what were you doing at ss14???? :p
Vanos seal probably together with my oil change bro, another 3k km to go... but kalau nak buat together can propose lah. My next mod would be angel eyes... tgk kau punya sudah kena racuns!
bro swansonsz, then you have to come for TT at MMZ Bkt Jelutong tmrw, strider74 wld share his 'escapade' at ss14.......hehe
Looks like my job is done here...hahaha
4/6/07:
took delivery of my E46 318i M43
16/6/07:
Cobra alarm system (metalink) - RM1650
30/6/07: (24,000 km service)
5 ltr engine oil - 112.50
1 pcs oil filter - 35.00
4 pcs plug - 140.00
1 pcs air cond micro filter - 98.00
1 pcs fuel filter - 88.00
1 pcs auto filter (atf) - 125.00
1 pcs auto gasket (atf) - 55.00
1 set front disc pad - 175.00
1 pcs front disc pad sensor - 45.00
7 ltr atf oil (ori) - 455.00
radiator coolant - 30.00
labour (for major service) - 160.00
wash - 20.00
TOTAL= 1,538.50
14/7/07:
power window rear left - 370.00
18/8/07:
alignment - 37.50
4 valves - 20.00
4 michelin xm1 205/60r15 - 1060.00
TOTAL = 1,117.50
10/9/07
vkool elite & v40 - 2600.00
1 set crystal no plate & casing - 170.00
TOTAL = 2,770.00
19/10/07
repair 7" crackline - 200.00
27/10/07 (36,000 km service)
4ltr engine oil fully synthetic & oil filter - 190.00
top hose - 140.00
expansion tank - 300.00
TOTAL = 630.00 (including labour)
12/12/07
3 lightbulbs (rear) - 15.00
31/12/07
front brakepad (ate) - 160.00
front lower arm bush - 350.00
alignment - 50.00
adjust rear camber - 50.00
off wheel balancing - 32.00
on wheel balancing - 16.00
TOTAL = 665.40 (plus tax & labour)
18/2/08
1 h7 headbulb - 28.00
22/3/08 (48,000 km service)
oil filter + 4ltr engine oil + labour - 190.00
22/3/08
bought @ inner power
rear ate disc pad - 115.00
rear brembo brake disc set - 310.00
TOTAL = 425.00
labour charge to change rear brake pad & brake disc - 70.00 (on 1/4/08)
31/3/08
alignment & balancing - 155.40 (plus tax & labour)
5/4/08
new alpine ida-x001 ice+speakers - 3,000.00
17/5/08
re-spray right hand side of the car - 600.00
2/7/08
19/7/08 (60,000 km service)
4 ltr mobil 1 engine oil - 198.00
1 set auto filter & gasket - 168.00
6 ltr ori auto oil (atf) - 270.00
labour - 120.00
TOTAL = 791.00
27/8/08
1 pcs radiator assy - 750.00 (plus labour)
3 ltr coolant - 60.00
TOTAL = 810.00
30/12/08 (72,000 km service)
oil filter - 28.00
labour - 35.00
TOTAL = 63.00
31/12/08
alignment & balancing - 181.65 (plus tax & labour)
2/1/09 (yet to be installed)
brembo front brake disc set - 350.00
front disc pad set - 130.00
TOTAL = 480.00
labour to install the disc and pad - 160.00 (on 21/2/09)
17/1/09
re-setting alarm system - 350.00
29/4/09
connector pipe for coolant - 58.00
coolant hose (rear) - 175.00
labour - 85.00
TOTAL = 318.00
10/6/09
(labour) oil filter housing gasket & O ring - 90.00
gasket - 28.00
2 pcs O ring - 20.00
1 pcs belt - 70.00
TOTAL = 208.00
06/07/09
re-spray 16' rims 4pcs - 200.00
11/07/09 (84,000km service)
oil filter - 45.00
labour - 45.00
TOTAL = 90.00
01/08/09
labour - 60.00
fr lh window lifter - 430.00
TOTAL = 490.00
06/08/09
fr h7 lamp bulb - 38.00
15/08/09
205/55/zr16 michelin pp2 4 pcs - 1,688.00
steel valves 4 pcs - 48.00
balancing, alignment, camber - 143.00
TOTAL = 1,886.15 (plus tax)
18/01/10 (96,000km service)
1 pcs oil filter - 45.00
4 pcs bosch spark plug - 140.00
2 pairs brake pad (front & rear) - 370.00
2 pcs brake sensors - 76.00
oil service - 45.00 (oil self-supplied)
labour - 260.00
TOTAL = 936.00
05/02/10
top up air-cond gas - 50.00
02/03/10
1 pc front emblem - 52.00
2 pcs grommet for emblem - 6.00
TOTAL = 58.00
13/04/10
front R/H window lifter - 430.00
labour - 80.00
TOTAL = 510.00
20/04/10
ignition coil - 520.00
diagnose engine misfire & labour - 60.00
TOTAL = 580.00
03/05/10
air vent valve - 185.00
labour - 45.00
TOTAL = 230.00
18/05/10
air filter - 38.00
microfilter - 65.00
(self installed)
TOTAL = 103.00
12/06/10
alignment + balancing = 183.75
17/06/10
front right hand bumper bracket = 130.00
03/07/10 (108,000km service)
engine oil - 209.00
oil filter - 45.00
rear left wheel bearing - 135.00
brake fluid - 38.00
labour - 305.00
TOTAL = 732.00
12/07/10
alignment - 131.25
14/08/10
ori wiper set - 110.00 - self DIY
front windscreen lower panel cover - 228.00 (installed on 13/11/10)
TOTAL = 338.00
13/11/10 (120,000km service)
engine oil - 209.00
oil filter - 45.00
deflect pulley 2pcs - 140.00
fan belt - 65.00
labour (service + install windscreen cover) - 90.00
TOTAL = 549.00
19/11/10:
4 pcs 225/45r17 Eagle F1 Asym - 2060.00
(installed on 3/1/11)
3/1/11:
steel valve - 10.00
alignment - 125.00
fix new tires - 48.00
balancing - 20.00
TOTAL = 212.65 (plus tax)
29/1/11:
oil sump gasket - 55.00
drain & replace oil - 25.00
labour - 180.00
TOTAL = 260.00
26/3/11:
1 set front brake pad - 280.00
2 front brake disc - 520.00
brake fluid - 35.00
2pcs engine mounting - 290.00
FLH lower arm - 150.00
labour - 100.00
TOTAL = 1,375
13/4/11:
1 set of wheel locks - 135.00
14/5/11 (132,000km service)
engine oil - 198.00
oil filter - 28.00
labour - 20.00
TOTAL = 246.00
27/6/11: (self installed)
1 bulb - 3.00
rear boot lighting set - 175.00
TOTAL = 178.00
3/9/11:
whole car re-paint - 2+++.00
8/9/11:
valve cover gasket - 40.00
oil filter housing gasket & o ring - 22.00
U seal - 25.00
labour - 150.00
TOTAL = 237.00
8/10/11:
trunk lid grip - 410.00
(self installed)
13-19/11/11:
new leather seats cover
re-upholster roof lining
RM2,800.00
24/11/11:
coolant - 30.00
8/12/11 (144,000km service)
4L engine oil - 198.00
oil filter - 28.00
1 set lower arm bush - 220.00
1pc R/H lower arm - 150.00
fuel filter - 65.00
oil level sensor - 200.00
ATF gasket & filter - 180.00
5L ATF gear oil - 300.00
bypass air-bag - 80.00
labour - 125.00
TOTAL = 1,546.00
28/12/11:
1pc valve (spare tire) - 4.00
alignment - 125.00
balancing - 56.00
TOTAL = 185.00 + 6% GST
31/3/12:
thermostat - 195.00
radiator cap - 45.00
emission control air pump hose - 150.00
labour - 30.00
TOTAL = 420.00
23/4/12:
battery - 320.00 (it finally died on me after almost 5 years of daily usage)
3 bulbs - 11.00
labour - 30.00
TOTAL = 361.00
12/5/12:
expansion tank - 240.00 (last change was in 2007)
labour - 40.00
TOTAL = 280.00
29/6/12: (installed on 30/6/12)
Front
L&R spring strut - 620.00
2 pcs protection tube - 30.00
2 pcs add absorber - 50.00
2 pcs guide support - 140.00
Rear
2 pcs shock absorber - 320.00
2 pcs guide support - 60.00
TOTAL = 1,300.00
30/6/12:
4L engine oil - 208.00
oil filter - 28.00
labour - 150.00 (including install all 4 absorbers)
TOTAL = 386.00
27/7/12:
1 set front brake pads - 150.00
1 set rear brake pads - 145.00
front & rear brake sensors - 70.00
brake fluid - 35.00
labour - 50.00
TOTAL = 450.00
15/9/12:
cylinder pipe connector - 55.00
block pipe connector & o-ring - 65.00
water hose cylinder (heater) - 130.00
water hose bypass - 130.00
coolant - 18.00
air hose vacuum cover - 30.00
air mass sensor - 450.00
labour - 100.00
TOTAL = 978.00
07/01/13
alignment & balancing etc - 181.00
TOTAL = 191.85 (plus GST)
05/02/13
oil filter - 28.00
labour - 20.00
TOTAL = 48.00 (free oil from AD)
02/03/13
rear left reverse light assembly - 175.00
(self installed)
06/03/13
top hose - 165.00
coolant - 18.00
labour - 80.00
TOTAL = 263.00
Hi.....QD250 :)
Tqvm sharing the info.Truly very happy knowing.
Take care
Alby 325i :):)
As preventive and based on BMW SC schedule I need to replace the followings
Control arm bush RM 120 (M3) from Munich segambut
Long shaft bush (coupling) SGD 32 Lamforder from eng soon
Long shaft bearing BMW original SGD 65 from eng soon. You can also get febi from Munich segambut for RM80
Labour at autocraft sunway (ah loon) rm230 inclusive wheels alignment
Bro
I was charged for RM245 for brake fluid flush and changed today. I am not satisfied but wanna check with you if it is reasonable.
shasall;819423 said:
Bro
Its on the high side bro, 1 liter of BMW DOT4 is RM35 and u just need one bottle. Cleaning rotor and pads, flushing, bleeding and testing done at my regular shop normally cost me rm50
anaksarawak;819428 said:
Its on the high side bro, 1 liter of BMW DOT4 is RM35 and u just need one bottle. Cleaning rotor and pads, flushing, bleeding and testing done at my regular shop normally cost me rm50[/QUOTE
Bro
I believe so. Thanks so much. Can you recommend me your workshop pls. The one i'm going is expensive when i compare to those posted by our fellows here but this time around they are too much. I never ever want to go there again
Bro
You are welcome to check the maintenance thread as we post where we did our repairs. Normally I will go to visit the shop for review and ask for quote then use my ipad check what others paid for and go back to the same shop to ask for the same. :) otherwise say.. so and so did his for this much and why yours is higher. Hahahahah me very lokek..
Bro,
Noted with thanks.
It all started when i did my regular servicing yesterday and the mechanic said brake fluid was dirty needed to be changed. My fault i didn't ask for the cost. i estimated around RM100.
When i received the bill, wahh......i kena this time. A forumer did posted his anger for this workshop before and since i was a regular customer, i didn't take note. A lesson learned.
hi any one want to know or check bmw parts price please call me 0122967887, you can check and compare tq.
shasall;819611 said:
Bro,
Noted with thanks.
Hi Shasall don't mind to share which workshop is it ? cause i noticed you are from Seremban. Thanks
Hi Guys,
Cold start this morning, RPM was erratic and engine even died once. So took to her to my mech. Found out ignition coil in cylinder 5 kaput. Changed and baby is good as new!
Cost: Ignition coil RM180 + RM50 labour.
krsna86;819756 said:
Hi Guys,
Care to share where did you replaced the coil?
BA is only selling each for RM80.
Other coils tend to fail one after another hence it's advisable to change all together.
