E46 parts & maintenance
Had a radiator leak last weekend. Discovered a small fracture on the coolant reservoir. That part was replaced for RM285-00. Replacement of coolant costed me RM50-00 and I also replaced air filter element for RM30-00. Labour which Benson Auto (SS2)charged for a speedy same day 2-hour job amounted to RM30-00. E46F helped me confirm the pricing was appropriate. Thanks!
Just did mine got the stock from stuttgart, PJ. They charge me
lemforder front disk a pair for RM 270 and
RM 145 for front brake pad ATE.
Labour RM 60 but was done in Klang yesterday. Happy with the price. Recommended to others. :)
The charges for work done on my E46 318iA N42 (mileage = 50,953kms) for "engine misfires/vibrates at idle & at slow speed" :-
1) checking function of the digital motor electronics (DME) for engine misfiring/shaking RM66
2) checking ignition coils RM66
3) replacing ignition coils RM22
4) charges for replacing all four (4) ignition coils (code: 12131712219) RM580.96
5) replace HOSE under the engine cover (code: 11157503524) RM65.68
6) Service tax RM7.70
TOTAL CHARGES RM808.34
Hey fellas. May I request for those who have done Inspection II on their E46s list what components were replaced and how much it costed? Please include lubricants etc. Thanks!
This is my 1st time service at Roadster Motorsports - Pandah Indah
Spare Parts
Oil filter (1) RM35.00
Engine Flash (1) RM60.00
Fuel Line Clener (1) RM60.00
Rear Brake Pad (1) RM160.00
AirCond Filter (1) RM155.00
Service Charge
Inspection Service RM65.00
Break Pad Service RM20.00
Lubricants
Helix Ultra (4L)
Helix Ultra (1L)
Spare Parts
Service Charge
Lubricants
Helix Ultra (4L) RM168.00
Helix Ultra (1L) RM46.50
Spirax A LS 90 Assy Oil RM33.00
TOTAL : RM837.50
This is the 1st time I'm bring my 318CI for serive, do you think the price are reasonable or expensive. I'm happy with the service quality provided by Roadster.
Service at 68628kms (non-AB centre):
Caltex Havoline SAE10W-50 Fully-Syn (RM135.30 - friend is a distributor!)
Oil Filter (RM34.00)
Labour plus reset OBC (RM110.00)
Was there anything else I should have done?
E46 318 2000
Just changed some parts as follow :
front lower arm bush - RM320 (2 pcs) OEM
front link - RM180 (2 pcs) OEM
Labour charge for above - RM 120
E46 325i 2002 65kilometer
For checking engine stall, sometime it works and sometime it doesn't.
Parts changed as follow:
Camsaft sensor RM350
fuel filter RM130
labour RM 50
My car now run like brand new.
Juan, mine's due for Inpection II, will keep you posted.....trying to find the time to send in my car (and also arrange for a spare car too)
Heard that KrazeePete did his for $8grand or something like that....pengsan!
Oil change 4 lt Shell Helix Ultra RM 168
Oil Filter RM45
Right rear Window Lifter RM385
Workmanship RM80
Total RM 678
Inspection II is the same as Inspection I with the following extras
Renew Spark Plugs
Intake air silencer: renew air cleaner element.
I don't think this comes close to RM8k!
BTW this is in your BMW service Handbook
Inspection II
Inspection II including old oir disposal RM 220.00
Shell Helix Ultra 6.5L RM 273.00
Steering Fluid RM 4.50
Oil Filter RM 41.72
Spark Plug RM 432.30
Air Filter RM 95.27
Microfilter RM 144.40
Windshield Washer RM 9.77
Fuel Filter RM 313.65
Bolt RM 9.97
Clamp RM 6.90
Ribbed V-Belt (Fan belt) RM 169.76
Replacing Fluid in ABS/ASC+T RM 44.00
Brake Fluid RM 56.28
Replaceing Power Steering Intake Pipe RM 77.00
Intake Manifold RM 112.17
Pipe Clamp RM 5.12Replacing Power Steering Return Pipe RM 77.00
Return Pipe RM 206.28
Pipe Clamp RM 6.20
Replace Brake Front Pads RM 77.00
Brake Linings RM 382.10
Check Funtion of DSC Light RM 33.00
Cover RM 5.26
Bulb RM 50.18
Total Labour RM 528.00
Total Parts RM 2047.00
Lubricant RM 277.50
Total RM 2852.83
Service Tax 5% RM 26.40
Gross Total RM 2,879.23
hi all,
i'm new in this forum, plannin to buy 1 e46 318i unregistered,any comment? how about maintenence wise???? what should beware of service ? changin oil? wat else need to be service???thanks.. ;) :yes:
My front driver power window finally caved in last night with a broken regulator or lifter. It was about time since all windows been working fine for the last 4 years and 76,000 kms. I tried to arrange for it to be fixed at Auto Bavaria but they could only attend to my car on Thursday (16/6) at Sg. Besi or next Monday (20/6) at Glenmarie. So, I decided to give it to my regular mekanik at Benson Auto SS2. The proprietor of this outlet is a BMW afficiado and owns a E39 528i. The service was as usual very impeccable with immediate attention and detailed explanation of what went wrong and has to be replaced. The final bill came up to RM480 (RM430 for part; RM50 for labour). The parts are original either from Bavarian Auto or Stuttgart. The repair was done quite well and the window works flawlessly now. I checked with some forummers on how much it would have costed me if I insisted on getting it done at Auto Bavaria and was quite pleased to know I got it done cheaper. Auto Bavaria would have charged RM560. Benson Auto's job was done in less than 90 minutes. However, the cifu there alluded to my thinning brake pads.... and I cried!! :p
my front driver window gave in abt 3 weeks ago too...need to replace the whole lifter...costs me around rm700 for a new lifter n rm100 for labour...let's hope that my passenger's side window won't fail in these couple of months...it is expensive to maintain a bmw..that is all i can say!!
Originally posted by bmchai@Jun 13 2005, 10:57 AM
changed my power window rear right at selvam's
Rm350
& labour Rm50
Oh yes, my mekanik did tell me b4 doing the job that pricing is different for front and rear windows but since I hardly use rear power windows, I won't even know if koyak dy... :p
marco : RM700 + RM100 fer ci? hmm, perhaps u might wanna get 2nd opinion eh dude?
rgds, B)
kahar abdullah
