Bro..please check the fuse behind the CD changer first... It happened to me when i first bought the car... After i change the fuse, it works fine bro...
Hello Daiichi,I am sorry for not giving a quick reply,if you're still interested,and make sure that your audio sys. is not a japan spec (which has 1 antenna wire and 1 ori cd changer wire), because this player is a euro spec (which only has 1 female socket at the back for the cd changer) ,that means your car audio sys. should be provided with 1 wire that is a cd changer that included the antenna wire in one.
So how is it Daiichi..? let me know if you are confirmed about your car spec sys.,other wise it won't be as easy as plug and play.
Anyway the reason I am explaining all that just simply I don't want anyone to repeat the mistake I did.
Thanx and looking forward to hear from you soon..
Hi Daiichi,
If your car happen to be Japan Spec, I got a BMW Professional CD Player taken out from my e46. It's in very good condition and was replaced for audio upgrading. Please PM me if you interested.
