Vincent Hor
- May 28, 2005
- 1,363
I got it done by Albert (WP Auto). His mobile 012-2017792
zeedo;726787 said:The worst symptom of a failed vacuum pump is your brake pedal feels hard and makes it impossible to stop the car properly. When that happens it's not the o-ring that failed but the vacuum pump unit itself.
Vincent Hor;738331 said:Ibrahim Hanif, this is probably what you are looking for.
Vincent Hor;738621 said:Bro, Can u ask your mechanic to verify if this is the problem? If yes, then I will get it for you. How is your brakes? If they are already hard then no point to change these 'O' rings cos you will need to replace the complete vacuum pump.
Do let me know.
Vincent Hor;738703 said:Ok then. Please PM me your address.
astroboy;756513 said:SALUUUUUTE!!!!!! :top:
Those photos a bit small la.. It's like watching porn on 160x320 resolution.. arggghh! :motz:
Load them into photobucket or something la.. I wan't to see more! :love:
Rocker cover gasket didn't change ka?
So you remove the cam shaft and Valvetronic motor to access spark plug tubes No. 3?
How's the re-installation of rocket cover? Any leak after that? Did you apply gasket sealant to the rocker cover gasket?
Iceduke;756517 said:..
Oh u own N46...I can offer my services hahaa![]()
