E46 318 2.0 - Issues at 100k km
Sludge formation informations.
Dear Planta and to other bros. whom it may concern;
Here's some interesting article concerning the sludge formation in the engine.
Planta, i really appreciate your effort in sharing us your experience and concern with regards to this very interesting topic. Your time in taking photos and downloading in this forum makes a very intersting discussion. Although i may also agreed in some sense of what Astroboy was saying earlier in particular following the recommended service interval. In anycase it's up to individual perogative to decide. I am for one, is changing my oil earlier just to be on the safe side. (anyway my car is not brand new. warranty left 3 month only).
Planta, can do us a favor, check what brand of petrols being used by these guys who did the overhaulled job. My hyphothesis is it could also due to the type of petrol being use. (Please read the article below for furthur clarification)
Anyway here's the article and its links for your reading pleasure.:top:
This is a printed article from www.theautochannel.com, dated June 1996. It is sponsored by Pennzoil Motor Oil Company and that's why there is reference to that product in the article. I found the article informative for all to read regarding the formation of the dreaded engine sludge that many Toyota owners are finding in their vehicles.
__________________________________________________ ________________
In the last issue I said that mechanics should be called "automotive systems analysts," because the knowledge and experience we must acquire to be good truly earns us that title. I also said the engine's oiling system was an all-important system. In this issue, I would like to take the oiling system discussion a bit further and talk about a topic automotive analysts everywhere will be able to relate to: sludge.
Horror stories have been passed around for years about this motor oil or that motor oil causing sludge. The fact of the matter is that no motor oil causes sludge. In fact, motor oil actually helps prevent sludge.
Then where does sludge come from? In our continuing quest for oiling systems knowledge, I thought it would be good to take a minute and further investigate what sludge is, how it forms, and how to prevent it. I also want to explain how a top-quality motor oil, like Pennzoil, keeps engines free of sludge, deposits and corrosion.
The Sludge Monster
We've all probably taken apart an engine or seen an engine that's been consumed by the "sludge monster." It's not a pretty sight and has been the cause of death of many engines. The first clue that an engine has been inhabited by the sludge monster usually becomes evident during an oil change (when the thick goo dribbles out the oil pan drain hole or nothing at all comes out). We usually identify the fatal cases of sludge monster victims after the vehicle arrives at the shop under the auxiliary power of a wrecker.
Contaminants and Sludge
Contaminants are deadly enemies of an engine. They enter with the air flow and are also generated by the friction of metal against metal. These facts may astound you: for every 100 gallons of gasoline burned in an engine, the following by-products are produced:
90 to 120 gallons of water
3 to 10 gallons of unburned gasoline
1/2 to 3 pounds of soot and carbon
1/4 to 1 pound of varnish
1 to 4 pounds of sulfuric and nitric acid
A measurable percentage of these by-products ends up in the motor oil. Detergents and dispersants in the oil must be able to keep most of these con-taminants neutralized or suspended in the oil as microscopic particles so they don't form sludge, damaging deposits and corrosion. When the waste materials are dispersed properly in the oil, the filter can trap the larger particles. During an oil change, the contaminants too small to be filtered are re-moved with the engine oil. Looks good on paper, right? So much for the perfect world. It's important to note here that good air filters and good oil filters trap more contaminants than lesser quality filters, making the oil's job easier.
Paraffin-based Crude Oils
Most people relate the word paraffin to candle wax. This is a correct association, BUT one of the most incorrect and widely circulated misconceptions about sludge is that it forms more easily in paraffin-based motor oils. This couldn't be further from the truth. All major motor oils, in fact, are formulated using a paraffin-based crude oil. Naphthenic-based crude oils are actually more likely to form sludge in an engine than oils formulated with paraffin-based crude oils. This is due to the higher breakdown resistance of paraffin-based crude oils. O.K., so how does sludge really form?
How Sludge Forms
Sludge formation begins when the chemically suspended particles of contaminants begin to settle out of the oil. It's a fairly daunting task for engine oil to suspend all the contaminants thrown at it, and any engine oil can do this successfully to a point. Pennzoil, and some other quality motor oils, are able to perform this task more effectively and for longer periods of time. But eventually, if the oil is not changed often enough, a "breaking point" will be reached. This breaking point is either when there are too many contaminants to handle or when the oil's chemical defenses are weakened, and it is caused by two main things: excessive accumulation of contaminants in the oil and chemical changes in the makeup of the oil itself (depletion of the additives and oxidation).
As more particles are suspended, less of the additives are available to do their job. Knowing this makes it easy to see why too much time between oil changes can be one cause of the oil reaching its "breaking point".
A Surprise Visit From the Sludge Monster
Another cause may surprise you: running the engine low on oil for a prolonged period of time can cause sludge. The detergent and oxidation inhibitors are important components of the additive package that prevent sludge from forming. When an engine is run low on oil, these additives have to work overtime to do their job. There is simply less of the additive package available to do the work of suspending particles and preventing oxidation (thickening) of the oil.
Here is the surprise part: running an engine just one quart low on oil for about as long as some technicians work in one week (about 55 hours) can increase the viscosity, or the thickness, of the oil by over 1000%!!! I don't know many technicians, or car owners for that matter, who would like to run 5,000-30,000W oil in their car's engine. If you factor the effects of the increasing use of self-service gas stations into the equation, you can see how the sludge monster can unintentionally be invited to pay a visit to so many engines.
Eliminate Surprises
The sludge monster's invitation can be repeatedly rejected. To keep the sludge monster looking for a dinner date in someone else's engine, use a quality oil like Pennzoil, with its super powerful Z-7¨ additive package and change it at recommended intervals. It's like making sure the Kryptonite never gets near Superman.
We're the Automotive Systems Analysts
Our customers look to us to know the various vehicle systems and how they operate. The oiling system is no exception; it's the life blood of the engine. I hope this information adds to your ever-growing base of automotive technical information and helps you to explain motor oil's importance to your customers. Next issue, now that the sludge monster is running scared, we'll take a look at the other additives in motor oil that weren't discussed here. We'll see that the slippery substance is truly a chemical wonder.
* Pete Sullivan is a technician and owner of Sullivan's Advanced Auto Care in Houston, Texas. He is a triple master certified by the National Institute of Automotive Service Excellence (ASE). He holds a B.S. degree in Physics and Chemistry.
http://forums.bimmerforums.com/forum/showthread.php?t=684420
This forum discuss at length about the sludge problem in BMW
http://answers.google.com/answers/threadview?id=77287
this guy explain the caused of sludge due to the antifreeze additive in the motor oil.
Hi Famy
Good article, thanks. Most of these guys use Petronas petrol. If I refer to the below quote from the article, it does support the simple theory that prolong use of engine oil will cause sludge. I believe engine oil has its distinctive qualities and limitations. 25,000 kilometers for engine oil change is too long.
planta
"Pennzoil, and some other quality motor oils, are able to perform this task more effectively and for longer periods of time. But eventually, if the oil is not changed often enough, a "breaking point" will be reached."
"running the engine low on oil for a prolonged period of time can cause sludge. The detergent and oxidation inhibitors are important components of the additive package that prevent sludge from forming. When an engine is run low on oil, these additives have to work overtime to do their job. There is simply less of the additive package available to do the work of suspending particles and preventing oxidation (thickening) of the oil."
alternative.........
Dear Planta,
What is your opinion if we use normal (non synthetic oil ) in our engine, but we change it every 3000 km or so. We then change filter after about 9000 km then.
would that be better than using fully synthetic and change at 9000km and its filter. economic wise the cost is pretty much the same.
I did this to my Toyota MR2 and its in perfect condition, i dont know about the e46 BMW. Just need other opinion or share experiences. Thanks Bro.
Some other photos of MR.Chendol......
Prevention is better than Cure.
Read more about the above in link beemers club forum as mentioned above.
Famy;304912 said:
Dear Planta,
An Otai told me that the more frequent you change your engine oil, the cleaner it is. How long can the engine oil last and the interval can be determined by the choice between synthetic and non synthetic. If you use synthetic and change every 3k, I think it is a good strategy. It keeps your engine clean.
planta
This brings back memories. There was this E36 318i engine that was as dirty as this one. It was so dirty and clogged the engine oil upflow channels to the timing chain. It made the timing chain dry, dirty and noisy. The car could start but the noise from the engine was so loud like it was running without lubrication. The owner had to tow the car to my friend's place.
When we removed the valve cover, the engine smell like was bad and super strong. The smell stayed on our hairs and shirts by the time we were finish removing the engine head.
It took us several rounds of chemical wash and rinse plus scrapping to remove the dirt from the engine parts. In fact, when disassembling the engine, some areas had to be scrapped and remove the dirt to get to the nuts and screws.
planta
Just noticed this thread. I'm another believer and witness of sludge in e46 due to prolong engine oil use in our climate. Does BMW have a field test facility in tropical climate like ours (and as dusty as ours) to conduct their engine field test and prove that 25K km is fine here and repeat this cycle until cumulatively up to and beyond 100K km of use? They might if the sales volume in tropical climate region is significant enough than US+Europe+Japan+I don't where else being their top sales region.
My colleague told me that AB@PG reset his E46 service interval to 15K km not upon his request but 'recommended' by the service people there. Whether that's a gimmick to increase visit to AB@PG or not will never find an answer. ABPG was (is?) using Shell. Contrary to the Shell tv commercial, I felt completely refreshing draining out the old shell junk.
planta;274075 said:
Hi Astroboy
Cost varies between rm2k to rm6k. Price of parts icreased many times this year alone and may likely to increase again in 2008...So if you are buying a 100k km E46, get prepared to spend like rm10k for major service on engine and transmission depending on how many parts need to be changed.
As for the assurance of 25k mileage oil change does not cause sludge and massive dirt in the engine or due to additive and bla bla bla.. I have no technical data to prove otherwise. I only see the impact to the engines.
But then again, these guys are the ones putting stickers on the transmission oil pan that BMW ATF is lifetime warranty but how many BMW owners had to change the ATF after 100k km due to ATF issue. So, who would I trust, the logic or the technical advice like the one given on the ATF?
I would rather change my engine oil every 10k then take a risk on 25k km oil change.
planta
Thanks a lot PLANTA!!! Your detailed explanations are very helpful. May I know where is your workshop? I would like to have my car checed by you GURU!!!
Wish i had read this thread earlier ..... over the past 6 to 9 months, i was constantly sending the car to fix this and that leak .... car is 5.5 yrs old and at 105k kms....318i 2.0lt valvetronic model.
Just today i had the engine valve cover replaced ...ouch, expensive. The leak was not due to the valve cover gasket, which was also replace about 1 year ago.
Even my engine oil dipstick thingy leaked oil! Others are such as timing oil seal, oil filter seal etc etc.
Hi planta,
Roughly how much the cost for overhaul like that. I just bought 318i E46 2.0 at 126KM. will take the car this tuesday. Shop give 3 weeks warranty for engine. Will they cover the overhaul if I spotted leakage.
yeap PLANTA, heard your shop is in PNG. Where is it exact actually? Wouldn't mind to pay a visit perhaps to 'test' your knowledge....he he:rock:
anyway, mine is e36, do u familiar with e36??
Hi Bro
Just want to clarify... it is not my shop...I do not own a shop.
I hang out there to help a friend, to learn and fix cars as a hobby.
Have not done much fixing since I got back from the states 2 months ago... busy like a bee with work.
No need to test my knowledge la... I am not a mechanic by profession... I only share what I learn only la.
planta
Guys,
Aside from the mileage to measure oil change interval, how long before engine oil effectiveness deteriorates over time?
Cos, if we only travel a few km from home and work daily. I can't imagine changing engine oil every 1-2 years. Is 6 mths too long or 1 year acceptable?
Please discuss!
Hi Planta,
My name is Akim, i'm currently interested in buying the E46 318 2.0 03/04 model. Currently, i am still a newbie with regards to Bimmer cars, nevertheless i'm willing to learn the curves before owning one. If it is not a problem for you, is it possible to meet up and discuss about the basic things of identifying a good car and the preventive maintenance for Bimmer. Currently, i'm staying in Shah Alam and any place in Klang Valley will be ok on my end.
Best Regards
Akim
013-3321946
planta;297256 said:
just to share with you guys .. the engine pictured earlier had to be top overhauled as the engine oil was missing about 1.5 liter every 3 days... the odd thing was that there was no leaking and no white smoke ... we suspect the fume was filtered by the catalytic converter.
I was not present when they did the top overhaul but according to my friend a few valve seal was worned out plus due to the extreme dirt .. a few air holes in the engine head were blocked. They had to drill the hardened black dirt to clean it... I wish I was there to experience fixing this and taking picture of this and share in this forum... so... change you engine oil regularly guys...
planta
Sdr Planta.
My mechanic also recommended for top ovewrhaul - Mine is a 2003 320i E46 with 110K mileage. My real problem is check engine light always on, even after replacing O2 sensor, MAF meter, etc. Got sick of it already. The car drives OK despite the Check Engine Light problem. He recommends top overhaul but I am not sure that would solve the problem. He also said upgrade or replacing ECU is another possible solution (meaning, if top overhaul fails, replace or upgrade ECU). His "trial and error" approach to problem solving really pissed me off. I am looking for someone who could offer me the actual diagnosis and point to the actual problem.
Any idea? Your help and/or views from your vast experience is highly appreciated.
Thank you,
Sincerely,
- moe -
Hi Planta, can share with us the estimated cost for those leaks repairs? Items replaced and labor
