i have been having to top up the coolant about 1 cup every month and i hope to have traced it to the small and slow leak near the thermostat housin.gremoved the rad fan for better access and undo 4 bolts to remove t'stat housing.removed the t'stat and cleaned everything up.gasket was reused with a bit of sealant application and bolted everything back up again.lets hope this fixes the leak......
