E39 520i 2003 Gear Ratio
andre_lee
Dear Sifu,did any sifu know about the about model gear ratio...my gear box will be KO soon...any other model gear box i can use...many thanks...
andre_lee;593966 said:
Dear Sifu,
many thanks...
The e39 uses the ZF5HP19 gearbox exclusively. You'll have to source for a replacement unit of the same type.
i have 1 spare gearbox from Japan... interested PM me. is a 5 gears gearbox from 525i halfcut
Hi, would like to know what is your mileage now ? I was told that e39 gear box should be expected to end after 200K KM.
For gear, I read on BMW mag that 528 can use 523 tranny and 523 can use 520 tranny for better pickup speed. But for 520.....guess that is the lowest you can go.
Good luck and keep us update on the progress on costing, feel and related issue.
Happy new year.
Not all E39 gearboxes are interchangeable.
When my car had its gearbox overhauled and torque converter replaced, there was a 520i E39 in the shop for a gearbox overhaul as well.
I was told that the E39's, whether it's a 520, 523, 525, 528 or 530, all use the same basic ZF5HP19 gearbox. The only difference was in (1) the final drive ratio and (2) the size of the torque converter.
The most obvious of course is the torque converter. You can physically spot if the gearbox came from a 520 - it's physically smaller than a 525i's. The 525 & 530 share the same gearbox & torque converter set-up.
The 528/523 uses a similarly sized torque converter as the 525 but has a different lock-up clutch configuration from any other model.
I'd recommend sourcing for a gearbox specific to your 520 if replacement is absolutely the only way to fix your car. But if you ask me, a better solution is to try to get your gearbox inspected by a specialist to see if they can overhaul it. It can sometimes prove to be not much more expensive compared to getting a recond box from an unknown donor car with little or no service history.
Good luck with your gearbox, bro! ;)
