Ade;626240 said:Guys,
Where to get a low boost turbo kit? I know there's one from Mosselmann that's uses the stock ECU, stock pump and stock injectors. Where to get one in Malaysia? Does it really cost ~rm5k to have it fixed?
Thanks!
ALBundy;626621 said:If all the components are intact, it shouldn't cost 5k to get it "fixed".
Alternatively you can build your own turbo kit, with better performance than the Mosselman unit.
I did one before, on the M42 before I sold it. Last dynoed, more than 200whp, running with a TD04 turbine and Unichip with 328 injectors. The key to a good system is the header. Mosselman uses a "log style" header which is not efficient, a 4 to 1 header will be better in terms of spooling and a smoother+higher gas flow.
The header itself is about 1.4k, then go to chop for a used turbine (paid 400), the rest like intercooler, piping, blowoff valve and etc can be purchased new.
Cheers
Ade;626718 said:seems like a lot of work leh...don't intend to get massive power, something usable with the stock system....
turbology;628621 said:What Albundy suggested : 4-to-1 exhuast manifold (aka header), used TD04 turbine and Unichip with 328 injectors, this is as cheap as you can get and safe too. I am not sure how "simple" you want but this is as simple as it gets.
With the low boost you are aiming, you can skip the intercooler and blow-off valve. But recomended the BOV installed to prolong your turbo.
Running with Adjustable Fuel Regulator, is like you are building a time bomb.
Instead of "having a chat with sifu", how much do you know about TURBOCHARGE system ? or Supercharge ? or any FI method ?
I did my own turbo system with my previous car. When I said "built my own", I literally mean it. From welding mandrel bend 3" exhaust starting from downpipe, to tuning the fuelmap at all RPM, and all Throttle % with WideBand O2 sensor.
Cheers
ALBundy;628854 said:However, I would recommend a piggyback ECU to ensure proper fueling and to optimise the performance.
Cheers
turbology;629035 said:I thought BMW's ECU will readjust to fuel curve itself and that's why piggyback don't work well with Continental car?
From what I knew, to boost a M50/M43 engine well & reliable, will cost me about 20k. I guess I am wrong.
